SolaraGuy.com • View topic - head unit?
head unit?
head unit?
Postby solaraguy777 » Fri Mar 07, 2003 10:56 am
u KNow on our head units we have a double slot , do we have to get only double size head units or willl the reg size 1 fit?does any1 have pics of there head units?
thanx
Ram air intake w/ k&N filter, Trd exhaust,
Hp racing evo 18's, Tokico/Eibach combo.
solaraguy777
Postby Blaze » Fri Mar 07, 2003 10:58 am
u can fit a single din size headunit, u can get a pocket to fit underneath or on top of it, i used to have one but now i have an indash lcd monitor
Blaze
Postby TadS » Fri Mar 07, 2003 11:33 am
Yeah, Like Blaze said. Get a good quality kit if you going to do a single DIN. Some of the cheaper kits fit pretty bad. I have a single DIN kit in my car. If you want to see it, there is a picture on my Cardomian site.
TadS
Postby Yanks0114 » Fri Mar 07, 2003 11:47 am
I would reccomend buying the kit from crutchfield. Not only are their prices competitive, but they give you an in detail instruction booklet of how to install the headunit and they'll give you full tech support if you need any help
Postby i20solara02i » Fri Mar 07, 2003 2:13 pm
you can go with a double din like me
www.pbase.com/rufus129/inbox
richard
i20solara02i
Postby kondo » Fri Mar 07, 2003 3:31 pm
This is what a single deck looks like with the spacer.
http://www.sounddomain.com/id/kondo
Nick
kondo
SolaraGuy StickerGuy
Postby CrazyCraig » Fri Mar 07, 2003 3:36 pm
Check this out for a killer double din unit :o !
http://cgi.ebay.ca/ws/eBayISAPI.dll?Vie ... gory=32826
CrazyCraig
CrazyCraig
Postby solaraguy777 » Sat Mar 08, 2003 12:53 pm
thanx for all the help i def like the single unit better then double how much is the kit to make it a single size head unit? and wheres the best place to get good prices on monster cable amp wire kits?
solaraguy777
Postby Yanks0114 » Sat Mar 08, 2003 1:24 pm
Yanks0114 wrote:I would reccomend buying the kit from crutchfield. Not only are their prices competitive, but they give you an in detail instruction booklet of how to install the headunit and they'll give you full tech support if you need any help
The kits shouldn't be that expensive. Wiring harness will run you around $10 and face plate kit could be around $15
Postby Yanks0114 » Sat Mar 08, 2003 1:26 pm
solaraguy777 wrote:wheres the best place to get good prices on monster cable amp wire kits?
What gauge? Check ebay, but they usually have no name kits. Monster will be expensive reguardless
Postby solaraguy777 » Sat Mar 08, 2003 2:36 pm
r the noname brand wires any good? or it just worth spending the money and geting monster cable , um.. 4 or 6 gauge
solaraguy777
Postby TadS » Sat Mar 08, 2003 7:16 pm
solaraguy777 wrote:and wheres the best place to get good prices on monster cable amp wire kits?
Sounddomian.com doesn't offer Monster, but they have fair prices and a wide selection of quality amp wiring kits. Also, remember you get what you pay for, especially on RCAs.
TadS
Postby indiglosolara » Sun Mar 09, 2003 10:33 am
i rec. www.ikesound.com they have good prices plus they dont charge for shipping.. check it out. i got most all my stuff at www.ikesound.com
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Guest » Tue Mar 18, 2003 2:36 pm
you know what looks sweet as hell when its done right? A din sized head unit, and a din sized EQ. Thats what i have done in my Camry, and in the process of being added to my Solara. I have the Kenwood KVT 911dvd with the Kenwood KGC-9044 eq/crossover in my cars and im my opinion they look awsome. but for some reason it will never compare to the flush look of a Double DIN head unit...i miss my kenwood 4010, but i love my touchscreeen 911. :evil:
Guest
Postby Turbo Camry » Tue Mar 18, 2003 2:38 pm
that last post was mine...i forgot to login. :evil:
Carlos
1997 Turbocharged Toyota Camry show car
Turbo Camry
