SolaraGuy.com • View topic - Running sub wire??
Running sub wire??
Running sub wire??
Postby Ruski » Tue Oct 10, 2006 7:13 pm
I have a 00 v6. and i cant find a good place to run my power wire for the amp. i wanan run it on drivers side not passangers. in my 00 accord i had the wire run in threw where the main harness came in from the engine bay but cant seam to find a place like that on the solara. Any ideas ? where did
you guys run yours ?
Sub CVR12 kicker
Momo box
Alpine digital MRD M300
Panasonic Cq-c7301u HU
thanks
Postby sbsolara84 » Tue Oct 10, 2006 7:19 pm
I ran mine through a previously drilled hole (pasesenger side) in the firewall. Prob. not a good idea, but the hole was already there from an aftermarket alarm system.
I heard that you can go around the firewall, but only from the passenger side.
I think i saw a thread about it here somewhere. do a search.
sbsolara84
Postby ---CAMRAZY--- » Tue Oct 10, 2006 7:33 pm
I drilled a hole through the firewall were the clutch master cylinder should be at since it was an auto.
Postby krook » Tue Oct 10, 2006 7:47 pm
CamrySE-soCALlara wrote:I drilled a hole through the firewall were the clutch master cylinder should be at since it was an auto.
mine too. if yours is A/T, locate the "fat propellor-looking" rubber piece covering your firewall (above your brake pedal) and remove it.
there should be a circle behind that piece on the firewall itself. nothing's behind it, so g'head and bore out a nice hole and finish up with a grommet.
krook
Postby Ruski » Wed Oct 11, 2006 9:35 am
yea i have an A/T and i saw that werid piece wneh i was doing drl tune off and Fog rewireing. but thanks alot guys
Postby funboy102 » Sun Nov 05, 2006 6:58 pm
so how about us M/T guys? any idea?
funboy102
Postby unbalancedwood » Sun Nov 05, 2006 7:09 pm
Inside your engine compartment, left side theres a grooment that goes to your glove compartment, its about 1.5" in diamater circle, cut a little slit in there and run it...
unbalancedwood
Postby Yanks0114 » Mon Nov 06, 2006 1:06 am
I ran mine through the passenger side:
Postby funboy102 » Mon Nov 06, 2006 10:09 pm
thanks a lot you guys, very helpful. and once it goes to the other side... i'm just gonna have to search for it the same way I did in my old Camry right?
funboy102
Postby tito53 » Sat Dec 23, 2006 6:58 am
---CAMRAZY--- wrote:I drilled a hole through the firewall were the clutch master cylinder should be at since it was an auto.
same here
tito53
Users browsing this forum: Google [Bot] and 9 guests
