SolaraGuy.com • View topic - Mid-bass...baffles?
Mid-bass...baffles?
Mid-bass...baffles?
Postby hari-bhari » Fri Oct 13, 2006 11:10 pm
I just installed my DLS MS6 speakers today, whoo they sound amazing, especially the tweeters. However, the midbass hits, but its not nice and tight like i thought it would be. I get the feeling that there is too much air in that panel and theyre just not punching like they should. I have them mounted useing the factory triangular mount, with a nice tight seal. But what can be done about all that open space? Has anyone used a baffle for the speaker, or will dynamat or deadening material be the best bet? Vibrations really aren't my problem, I just really want to tighten up that punch, becuase i know these spkrs are capable
hari-bhari
Postby netherland24 » Fri Oct 13, 2006 11:13 pm
RAAmat sells insole (or ENSOLE) whichever u cna put on pannels for rattle and u can use that to put behind the mids.
nice speakers by the way :)
00 SS Lara 277hp
05 DODGE RAM 1500 n/a
netherland24
Postby Mandarinsolara » Fri Oct 13, 2006 11:29 pm
subwoofers
Mandarinsolara
Postby hari-bhari » Sat Oct 14, 2006 7:27 am
well ive already got subs. will the sound deadening material help with tightening up the bass? i know itll help with rattles, but will it help with enhancing the bass?
hari-bhari
Postby netherland24 » Sat Oct 14, 2006 9:26 am
yes it will since there is more to deadner then anything it will give the speaker a more solid mount which will over more a direct sound and not rattle the door so it will sound alot better
00 SS Lara 277hp
netherland24
Postby hari-bhari » Sun Oct 15, 2006 9:26 am
so whats the best deadener? and how many sqaure feet should i buy
hari-bhari
Postby vin » Wed Oct 18, 2006 8:37 pm
These guys make great stuff for the money...
http://www.edesignaudio.com/edv2/index.php?cPath=24
Or if you prefer Dynamat makes excellent stuff, pretty expensive tho...
http://www.dynamat.com/
You will probably need about 12-15 sq feet or a door kit (this is for the inner sheet metal only, ~20 sq ft. for both inner/outer door skin)
I ended up using two door kits - one for each door, and my mid-bass is GREAT, I'm not even using my subs any more. :D
`97 ES300: 18" Volk Racing "SS" wheels. Tein SS
vin
