SolaraGuy.com • View topic - Where did you install your CD changer?
Postby 70weeks » Mon Mar 10, 2003 2:18 pm
Just ordered an FM modulated 10 disc CD/MP3 changer and need ideas on where I should install it.
Pictures would be great if you have them.
thanks,
-S
70weeks
Postby PureNocence » Mon Mar 10, 2003 2:36 pm
I have a Kenwood 10-disc changer and I installed it in the upper right ceiling of my trunk. There's that metal piece that you can drill it into and mount it, right under the rain guard. It actually works really well there, I haven't had any problems with skipping or anything.
PureNocence
Postby Luc » Mon Mar 10, 2003 4:05 pm
No picture, but I installed my friend's Eclipse 8-disc under his passenger's seat, actually bolted up to the metal, so when the seat moves, so does the changer, without obstructing anything. This was capable since his passenger's seat is non-powered, if it were, then it wouldn't be possible.
1998 S/C'd 1MZ-FE A/T
Luc
Postby nnnyyy » Mon Mar 10, 2003 11:01 pm
Can someone recommend me or link me to a cd changer that works with the stock 3in1 non jbl deck (1999)?
nnnyyy
Postby Luc » Tue Mar 11, 2003 10:39 am
I used the Eclipse 8-disc changer with an adapter to function with my friend's stock 3-in-1 in his '99, it won't matter if it's JBL or non-JBL. The only uncertainty is the indash 6-disc changer 3-in-1 starting in '00. Check out www.pie.net, www.blitzsafe.com, or www.peripheral-aamp.com for various adapters that accept different CD changers.
Luc
Postby BurningSolara » Thu Mar 13, 2003 8:45 pm
Also depends if you runnin subs. Because of just that mines is being mounted in the glove box.
So me placing 10 inch rims on my car will make it handle better? Cool.
BurningSolara
