SolaraGuy.com • View topic - installing woofers in door
Postby hari-bhari » Mon Oct 23, 2006 3:52 pm
what i did for mine was to glue and screw in the speaker to the original plastic triangular mount, so i could use the original holes in hte door. however, even though I know I have a nice tight seal between the speaker and the door, the bass is still not hitting. i was told that to get the bass like it should be, i need to use foam tape to create a seal between the speaker face and the outer skin of the door. if anyone has noticed, if you look at the backside of the grill on the door skin, there is a ring that sticks out towards the speaker so that it will meet the factory ones at their face. the factory speakers have a ring on their face to meet the ring on the door skin. has anyone tried adding foam tape to their aftermarket speakers to recreate this seal?
hari-bhari
Postby sparc » Thu Nov 23, 2006 9:56 am
I just cut new baffles using the triangular piece as a guide. used 1/2" MDF and just sealed it off with foam tape. its thin enough wood that you can still use the original holes, midbass sounds great.
You can live in a car but you can't drive a house.
sparc
Postby hari-bhari » Thu Nov 23, 2006 1:00 pm
original holes in the door?
hari-bhari
Postby sparc » Fri Nov 24, 2006 5:38 pm
yeah, with the little plastic screws. find sheet metal screws of same width, a little longer and enjoy.
sparc
