SolaraGuy.com • View topic - taking out rear speaker deck.
Postby aleki2424 » Tue Feb 27, 2007 2:15 pm
hey guys , i was looking to replace my stock 6 x 9' speakers with new infinity's , and the thing was a butt-load to even get to. i was wondering if anyone has a an idea on how to take the rack out. seems its bolted to anmost everything. diagrams would be a plus ., :onfire:
aleki2424
Postby RichD978 » Tue Feb 27, 2007 2:16 pm
too bad. search for it
RichD978
Postby Ruski » Tue Feb 27, 2007 2:17 pm
you have too pull the whole back seat and panels out.. heres a tutorial on removal off back seat to reach suspension but its in the same location and same process
http://www.solaraguy.org/viewtopic.php? ... +back+seat
Postby Ruski » Tue Feb 27, 2007 2:18 pm
Rich is correct Took me one second to search for it !!!!!
wow
Postby aleki2424 » Tue Feb 27, 2007 2:19 pm
damn y'all that was superfast. thanks for the replies. now let me read.....
aleki2424
Postby Ruski » Tue Feb 27, 2007 2:21 pm
haha no problem you owe me a beer !!!
any questions Pm me ill get back to you tonight
rear deck
Postby aleki2424 » Tue Feb 27, 2007 2:32 pm
ok, so i actually need to take all the inner panelling out. thats weird , but definitely worth a try. beer sometime ruskimafia :drinking:
aleki2424
Postby bassthrive » Tue Feb 27, 2007 4:25 pm
you gotta basically gut everything in the back. it really sucks, i have done it multiple times (6x9 speakers, suspension, satellite receiver, suspension again). let us know if you get stuck.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
did it
Postby aleki2424 » Sat Mar 03, 2007 9:37 am
i got to do the deed today. took me 1.5 hrs and was a real pain, but , it was done. i didn't even have to take out the side panels (note: not pillar panels)
and rear seat, and my new infinity's sound great.
something to note however , is that the rear deck uses three screws to mount the stock speakers , not four , as assumed, so be sure to get the nescessary mounts before pillaging the rear.
now for the front.... :)
aleki2424
did it
Postby aleki2424 » Sat Mar 03, 2007 9:38 am
aleki2424
Postby SolaraGuy22 » Thu Mar 08, 2007 4:42 pm
Nice double post.
When you do the fronts grab some of these http://www.crutchfield.com/S-q61Thoi5xF3/cgi-bin/ProdGroup.asp?g=762 I wish I would have done that to mine. It'll keep the water away from them when it leaks down your windows.
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby platypusfetch » Thu Mar 08, 2007 5:09 pm
SolaraGuy22 wrote:Nice double post.
That being said, PLEASE PLEASE PLEASE TEST BEFORE YOU PUT THE DOOR PANELS BACK ON COMPLETELY!!!!!!
I had a Dodge Avenger, used these baffles and they vibrated like MAD with the BASS. a little bit of insulating foam tape (sticky one side) took care of the problem, however it added an hour to the install, b/c I had to tear the whole shlock-shlock shlock door panel apart again.
but they did keep the speakers from getting messed up, that is for sure :)
best of luck
platypusfetch
front end speakers
Postby aleki2424 » Thu Mar 08, 2007 6:02 pm
sorry for that. guess i didnt need to prove my super slow connection.
but thanks for the info. other than baffle, does anyone know if i would need mounts for the 6.5's. am asking this since i realized a tard too late that the rears had three screw's to mount it which was probably stupid of them to do, therefore i had to get a little creative. also , do you think the dynamat stuff would make a difference.. i really dont intend that much thump up front, probably some three way infinity 963's
thank you
aleki2424
Postby SolaraGuy22 » Fri Mar 09, 2007 3:53 pm
I just used my existing brackets and drilled new holes. You should be able to do the same with yours. Dynamat never hurts you know. If you have the time and money go for it otherwise you can just apply if needed.
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby hari-bhari » Mon Apr 23, 2007 1:35 pm
i tried those baffles, they sucked and muffled my sound up. one thing that would help with midbass is creating a seal between the front of the speaker and the back of your door panel. i did this by removing the 1/2" thick cardboard ring off the front of the factory speaker (use and exacto knife and slowly pry it off) and then epoxied it around the face of my new speaker. then i got some foam insulation tape from home depot and put it all the way around that ring. now when you mount your speaker, the face of it will be sealed with the ring protrusion coming off the back of the door panel. made a HUGE difference in my sound, im surrrrious!
hari-bhari
