SolaraGuy.com • View topic - SubZone Enc with Infinity Sub?
Postby kronos98 » Sat Apr 12, 2003 7:38 am
I've got an Infinity Reference 1020W 10" sub and I want to find an enclosure. I checked SubZone out, and I think that's what I want to go with.
ZV-101
http://www.subzoneusa.com/zv_series.htm
The only problem is that it's 1.15 cubic ft, but the manual for my sub says it recommends 1.75 cu. ft. Is that a big problem? I have looked everywhere and coule not find a vented enclosure that big.
kronos98
Re: SubZone Enc with Infinity Sub?
Postby TadS » Sat Apr 12, 2003 10:09 am
You need a1.75 cu. ft. box for a 10 in. sub??? :o That is nuts. This is why I don’t use ported boxes myself. They are just too freakin big. I don't think anyone builds a prefabricated enclosure that large, as the biggest one I could find was 1.2. If you want to stay to spec you may have to have a custom job done.
TadS
Postby Yanks0114 » Sat Apr 12, 2003 10:41 am
Goto sealed. Don't even bother with ported.
Postby kronos98 » Sat Apr 12, 2003 12:32 pm
Yeah, this sub requires a lot of room. It needs 1 cu. ft. on each side of a bandpass enclosure, which I haven't found anywhere either.
http://www.infinitysystems.com/caraudio/product.asp?ProdId='1020W'&Ser=REF&Cat=SUB
It's ridiculous, but I think it's because: "A wopping 11.9 millimeter X-max delivers serious excurion." (I think they meant "whopping" and "excursion")
So you don't recommend any kind of ported enclosure? I like the accuracy of sealed boxes...I really do. But they don't have the "boomy" ring characteristic of bandpass boxes.
However, I'm beginning to see how unpopular they are. Best Buy and Circuit City never have any on display, which I'm taking to be a sign. I've never personally heard a ported enclosure, but I guess you guys all know what you're talking about. :)
One last quick question though: how much room do I have to play around a spec. like .75 cu. ft.? For a sealed box, my Class A sub requires .75 cu. ft. Should I get a .86 cu. ft. or .66 cu. ft. box? I want to get a SubZone enclosure, but they only have these two sizes that are close.
http://www.thezeb.com/caraudio/subzone_universal_sub_boxes.html
Should I get the H-101 (.86 cu ft) or H-101LQ (.66)?
kronos98
Postby TadS » Sat Apr 12, 2003 12:47 pm
kronos98 wrote:Y
I would use sealed, unless you are planning to be an SPL competitor, which probably isn't the best plan with that sub :).
Personally, I would go with the .86 because your sub is going to chew up alot of that extra with the magnet and whatnot.
Maybe you should PM Gunman, as he is the local expert.
TadS
Postby kronos98 » Sat Apr 12, 2003 2:40 pm
You're right. Sweet. Thanks.
kronos98
