SolaraGuy.com • View topic - USAcoustics Amp
USAcoustics Amp
USAcoustics Amp
Postby kronos98 » Sat Apr 12, 2003 7:50 am
Why do the specs on USAcoustics amps say 12.9v input power? Does that mean you have to get a power converter for them??
kronos98
Postby TadS » Sat Apr 12, 2003 9:54 am
I might be wrong here, but I think that is the voltage they test/rate them at. In other words they have a more realistic power rating than an amp that is listed at 14.4 volts, as your car usually doesn't give an amplifier that much power.
No, they should wire up just like any other amplifier.
TadS
Postby Blaze » Sat Apr 12, 2003 10:32 am
i have 2 us acoustics amps, they work pretty good :)
Imagination is the hood ornament on the car of creativity.
Blaze
Postby kronos98 » Sat Apr 12, 2003 12:33 pm
Sweet. I love the pricing on US Acoustics, and I've heard great reviews.
http://www.thezeb.com/caraudio/us_acoustics.html
kronos98
Re: USAcoustics Amp
Postby Yanks0114 » Sat Apr 12, 2003 3:41 pm
kronos98 wrote:Why do the specs on USAcoustics amps say 12.9v input power? Does that mean you have to get a power converter for them??
TadS was correct with his statement. You car usually runs around 13volts so the power measurements (watts) that they give should be pretty close to what you'll actually see.
Postby kronos98 » Sat Apr 12, 2003 4:12 pm
Man. This forum is like a godsend. You guys rule.
kronos98
Postby Blaze » Sat Apr 12, 2003 5:00 pm
were here to help :D
Blaze
