SolaraGuy.com • View topic - humm VS punch
humm VS punch
humm VS punch
Postby mailskobe » Mon Apr 14, 2003 10:11 am
I got my sub installed, i am kinda unhappy that i had to tap the high inputs and couldnt connect the RCA. Anyways thats another topic to discuss.
My question is, what is the most ideal setting for the sub AMP.
As you must know there are 3 settings on the AMP
INPUT LEVEL (4v to 200mV)
LPF FREQUENCY
BASS BOOST (GAIN)
I want more boom than the constant humm that you get when base is too high.
Anyone with any ideas. I played around a bit and saw that when the LPF setting is low and input level is high, you get sharper bass.
thanks,
mailskobe
2000 SZ V6, 5 speed, silver
mailskobe
Postby Gunman » Mon Apr 14, 2003 6:52 pm
what kind of amp are we talking about here?
Gunman
Postby Yanks0114 » Mon Apr 14, 2003 7:09 pm
He has a JBL BP600.1 Amp with Infinity Perfect Subs
Postby Yanks0114 » Mon Apr 14, 2003 7:11 pm
Try lowering bass boost on the amp. As you know I have the exact same setup as you do but connected with RCAs and the bass is perfect. It only hits when it should.
RCAs would be ideal, but you should be able to fine tune your system to sound a little better
Postby mailskobe » Mon Apr 14, 2003 7:14 pm
yanks, can you tell me your exact setup.
my system is not clean.
there is a lot of muddy bass, kinda that gives you headache!
mailskobe
Postby prophesized » Mon May 26, 2003 12:16 pm
put the lowpass at about 80hz
set the bass boost (which isnt the gain) to zero
for the input level (gain), start at 4 volts and slowly turn it up until you hear distortion then back it down a bit. do this with head unit volume at about 85%.
prophesized
