SolaraGuy.com • View topic - Good 6x9s and a 5/6 channel amp
Postby hari-bhari » Wed May 09, 2007 9:38 pm
im lookin to upgrade my rear speakers and install a 5 channel amp to replace my 4 channel that i can power all my spkrs plus a sub. i dont need top of the line, but my buddy can get me good deals on alpine amps through his company, so are these generally pretty good sound quality?
as for the 6x9s, i was looking at mb quartz cuz my friend has a set and they thump pretty hard, but what else could i go for? i just want some decent rear fill for probably <100. my fronts are really nice (DLS MS6), and i figure getting really nice rear speakers would be a waste cuz 1) nobody sits back there, and 2) theres nowehere to stick tweeters, so id have to go with coax. btw, anyone ever put holes into their side panels in the rear for tweets?
hari-bhari
Postby .onetohate » Wed May 09, 2007 10:44 pm
Alpines are right up there- but why do a 5 channel amp?
IMO-
1) 5ch/6ch amps are being pushed too hard which can cause it overheat and cut out. OR distortion (popping) at higher volumes.
2) Get some Infinity 6x9 3way (i wanna say kappas but not too sure) - those are bright as hell.
3) Hunt down those rattle spots and mat it up.
--- ----------- -----hope this helps.. . good luck!----- -----
.onetohate
Postby hari-bhari » Thu May 10, 2007 7:04 am
if i do a 4 channel then ill have to wire a separate amp for my sub, more hassle
hari-bhari
Postby .onetohate » Thu May 10, 2007 10:10 pm
Take ur current power cable- use a fused block distributor to split the power cable to two. Sand down another metal part for ur ground and use the RCA OUTPUT from the primary amp to send signal to ur secondary amp.
.onetohate
Postby hari-bhari » Thu May 10, 2007 10:15 pm
lol i know how to do it, i just dont want to cuz then id have to buy and mount two amps. is a 5 channel amp really all that bad??
hari-bhari
Postby .onetohate » Thu May 10, 2007 10:29 pm
i can honestly say- i've never tried it but did think about going into that route once before and i just couldn't fathom one amp doing all that work. lol.
.onetohate
Postby hari-bhari » Fri May 11, 2007 7:03 am
ill just order from crutchfield, so if it doesnt work out i can return it and theyll even cover shipping 8)
hari-bhari
Postby Solara08861 » Fri May 11, 2007 8:09 am
When I used to have my Sebring I had a PPI 5 channel amp pushing Infinity Kappas and 2 JL audio 12 inches and I had no problem with a 5 channel amp.
Solara08861
Postby blaK » Fri May 11, 2007 8:09 am
I have this amp for sale.
http://mobile.jlaudio.com/products_amps.php?amp_id=403
New in the box, never been used.
I had plenty of customers rocking this amp like a champ and no complaints.
blaK
Postby blaK » Fri May 11, 2007 8:10 am
blaK
Postby theprodigy79 » Fri May 11, 2007 8:30 am
5/6 channel amps are usually just two amps in one chassis... There is nothing abnormal or wrong with them, and there are some excellent models available. The amp blaK has for sale is actually a decent amp, you may want to check it out... I'm not a huge fan of the JL "e" series, but it will definitely do the job. If you're willing to pay a bit more, DEFINITELY check out the JL 500/5... It's an AWESOME amp for 5 channels.
As for Alpine, they've made a few different 5 channel amps... some were GREAT, others not-so-hot... What model can your buddy get for you? If you can get an older Alpine V12 5 channel amp, GO FOR IT. If it's a V-Power, skip it and go for one of the JLs or other companies.
Unfortunately not many (quality) companies still make 5/6 channel amps (and when they do they're expensive)... If you're willing to go used, check out PPI as well, as they used to make a few excellent choices.
theprodigy79
Postby blaK » Fri May 11, 2007 9:03 am
$300 plus shipping, it's yours. :)
blaK
Postby hari-bhari » Fri May 11, 2007 9:08 am
sorry, i meant infinity not alpine. i was thinking of this one:
Infinity Reference 5350a
http://www.crutchfield.com/S-w4yqw23MXB ... =108R5350A
And maybe some infinity reference 9613i
http://www.crutchfield.com/S-w4yqw23MXB ... I=1089613I
hari-bhari
Postby hari-bhari » Fri May 11, 2007 9:22 am
also i think if i ended up getting another 4 channel amp + a mono amp, i would go with diamond audio for the 4 channel, ive heard pretty good things
diamond audio d1 300.4
http://www.diamondaudio.com/content/view/76/81/
hari-bhari
Postby theprodigy79 » Fri May 11, 2007 10:36 am
To be honest with you, I don't have much experience with newer Infinity amps... their older stuff was alright, but I don't know anyone who run with their new stuff (beside speakers).
The Diamond amps are generally good stuff. If you did wind up separating out your mids/highs from your lows, the Diamond would be a pretty good choice.
theprodigy79
