SolaraGuy.com • View topic - New wires through door loom | power wire firewall
Postby bri_n_m » Sun Jun 10, 2007 3:35 am
I asked this question before and didn't really get a answer. So I went ahead and tried it....
I wanted to run my power wire down the driverside....
drilled a hole. put a bushing. ran 4 gauge. I circled the spot in red.
This is where it come into the cabin....you need to pop out the sound deadening....you will understand when you see it.
Ran 2 16 gauge wires through the passenger door loom. (havent gotten to the driverside yet.)
- I removed all the pannels along with the glove compartment.
- Used a hanger to fish the wires through....a bit of soap made it much easier.
from in the cabin showing where the loom enters.
new wires through the loom. cabin side.
new wires. inside door.
bri_n_m
