SolaraGuy.com • View topic - WTB sub amp
WTB sub amp
WTB sub amp
Postby kronos98 » Fri Apr 25, 2003 9:37 pm
I'd like to buy an amp to power an INFINITY Reference 1020W 10" subwoofer (250W RMS). I have heard good reviews about US Acoustics.
kronos98
Postby Yanks0114 » Fri Apr 25, 2003 9:43 pm
Is it just one reference or two? Also are they SVC or DVC and have you purchased them yet or are you still open for suggestion
Postby nkx1 » Sat Apr 26, 2003 3:48 pm
The Infinity Reference series are SVC. I don't know about the 10" version, but I have 2 of the 12" references, and they sound pretty impressive (much better than you would think). They are deep and loud, and I only paid $140 for 2. I saw them a while back at Circuit City for $79 for 2 12". At either price, they are a bargain imo, and I think you'll be very hard pressed to find a comparable sub for anywhere near that price. :fadein:
2001 SLE, Diamond White Pearl
nkx1
Postby kronos98 » Sun Apr 27, 2003 7:06 pm
yeah. the infinity reference 1020W is SVC. does that matter in determining an amp?
kronos98
Postby ZXLNT » Wed May 07, 2003 5:58 pm
Actually it can. Being a single voice coil woofer you may want to consider using a mono-block amplifier. Its just a single channel amp. Less wiring etc. If you had a dual voice coil woofer you could use a 2 channel amp with 1 channel on each voice coil. But then again you could wire the VC's in series or parallel depending on impeadance and use a mono-block amp again.
And yes the US Acoustics are good amps as well as crossfire. If you want to step up to a really nice amp look at some PPI's. The older ART series are very clean,good amps. U can find them on ebay usually..
ZXLNT
Postby CrazyCraig » Thu May 08, 2003 8:54 am
A Soundstream Angina would be a great amp to drive that sub.
CrazyCraig
CrazyCraig
Postby Guest » Sat May 10, 2003 7:12 pm
it's 4ohms svc
us acoustics amps will definitely do the job
Guest
Postby pro956 » Sat May 10, 2003 7:13 pm
Anonymous wrote:it's 4ohms svc
woops, that was me :)
AIM: pro956
2002 5-speed se v6
pro956
