SolaraGuy.com • View topic - my new trunk...
my new trunk...
my new trunk...
Postby bri_n_m » Sun Aug 05, 2007 11:52 pm
i've been working on this for a few months now when i have the time....
i needed space in my trunk and access to my folding rear seats so i came up with this.
removed rear speakers, installed amp rack under rear deck (2 amps and crossovers, sub in fiberglass box in corner)
bri_n_m
Postby Dawgz » Sun Aug 05, 2007 11:59 pm
damn, that looks like a real clean install! hows the bass with the sub all the way in the corner like that? does that matter or effect it at all?
Postby bri_n_m » Mon Aug 06, 2007 12:11 am
i wasn't really going for loud....more of a simple SQ system. it's only a 10. I also don't have rear speakers and left the holes open so it's a little louder. But it's pretty weak in SPL.
bri_n_m
Postby blaK » Mon Aug 06, 2007 7:06 am
Oh snap, how did I miss this one, sq all the way man.
Love the position of the amps.
blaK
Postby theprodigy79 » Mon Aug 06, 2007 8:48 am
Good combo with the Lotus / ED stuff... Must sound great :-)
Do the amps stay cool mounted upside down like that?
theprodigy79
Postby NVDIS1 » Mon Aug 06, 2007 8:55 am
:o Nice clean install and you still have trunk space! looks great!
Postby bri_n_m » Mon Aug 06, 2007 10:30 pm
thanks!
so far heat hasn't been a issue....yet. i may have to put in a fan eventually.
bri_n_m
Postby Ruski » Mon Aug 06, 2007 10:38 pm
Damn Nice and clean great job
Postby viper1400 » Wed Aug 08, 2007 1:23 pm
that looks cleeeeean! Nice job man.
"I'll get it when i have the money..."
viper1400
Postby 02RedSoul » Sat Aug 11, 2007 12:48 am
That is a great looking install man. Only problem with mounting the amps upside down is the heat issues that it can cause. But if that isnt a problem then stick with man. And I wanna know how that subs sounds being that it on one side of the vehicle.?
02RedSoul
Postby Patrik » Sat Aug 11, 2007 2:23 am
02RedSoul wrote:That is a great looking install man. Only problem with mounting the amps upside down is the heat issues that it can cause. But if that isnt a problem then stick with man. And I wanna know how that subs sounds being that it on one side of the vehicle.?
how can it be a heat issue if there upside down?
1999 SE V6 5 speed SOLD
Patrik
Postby blaK » Sat Aug 11, 2007 12:09 pm
Because there upside down.
Usually amps are designed right side up or flat on it's back down. Not upside down. If he doesn't abuse them he'll be alright.
Dispensing heat is the issue here.
blaK
Postby unbalancedwood » Sat Aug 11, 2007 1:12 pm
a few small computer/12volt fans should fix any over heating problems you may have...
unbalancedwood
Postby .onetohate » Sat Aug 11, 2007 1:25 pm
C L E A N . .
-note: heat travels up, so if the internals ov the amp are on top.. it basically marinates in its own heat. Thus, giving you more chances to overheat.
.onetohate
Postby PXLpainter » Sat Aug 11, 2007 2:04 pm
Overheating wouldn't be an issue in this case. Heat would only be a critical issue if they were mounted inside a small airtight box. Being in an open area like the trunk, there is enough airflow to compensate for any rising heat. ;)
Nice clean install! :up:
