SolaraGuy.com • View topic - bad problem...
bad problem...
bad problem...
Postby AzN_DrAgoN48 » Sat May 03, 2003 7:24 pm
i bought a new deck and harness and kit, and everything to do it. i removed the stock deck and replaced the wires with the harness. after connecting all the wires i test the new deck. nothing happens. i check all the connections and the fuse and still nothing happens. i replace it with the stock deck and again nothing happens. i don't know what happened. anyone have an idea.
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Postby happy_aggies » Sat May 03, 2003 8:56 pm
blown fuse?
happy_aggies
Postby Yanks0114 » Sat May 03, 2003 9:15 pm
There are many things that could have happened but chances are it was a blown fuse. Check your owners manual to find out what fuse controls the radio.
Anything weird happening with your car since you changed out the stereo?
Postby krook » Sun May 04, 2003 12:16 am
it's a blown fuse. check the fuses behind your coinbox on the driver's side.
krook
Postby roblectric » Sun May 04, 2003 5:45 am
Do not trust the wiring harness ground wire as a sufficient ground for your system.Try to find a spot on the firewall or somewhere that will provide a good connection to the cars frame. If the fuses are good,grounding is your porblem.
2000 SLE Gold
roblectric
Postby c2g » Sun May 04, 2003 11:50 am
did you make sure all the wires are right? it definitly could be a bad ground if everything else is right or like they said a blown fuse
99 silverstream SE V6 18" RSL nengans, Streetglow head and fog lights, Reverse guages,
Kicker L7 12" DVC, MTX amp, panasonic 903U, sirius, shaved emblems, clear corners,
altezza tails, K&N filter, mesh upper & lower grill so far
c2g
Postby Yanks0114 » Sun May 04, 2003 11:58 am
c2g wrote:did you make sure all the wires are right? it definitly could be a bad ground if everything else is right or like they said a blown fuse
Even if he screwed up the wires, when he put his stock back in and removed the wiring harness it should have worked.
...Unless he really screwed something up.
Postby AzN_DrAgoN48 » Sun May 04, 2003 5:38 pm
everything works now, when i replace the fuse, i didn't replace it with the right amp. everything works now after about 3 fuses lol. thnx everyone. the deck looks awesome.
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby Yanks0114 » Sun May 04, 2003 5:54 pm
Good to hear :D
Postby c2g » Sun May 04, 2003 7:59 pm
you never know i've seen some people connect things that aren't close to being right when they try to install stuf themselves
c2g
Postby Yanks0114 » Mon May 05, 2003 7:08 am
c2g wrote:you never know i've seen some people connect things that aren't close to being right when they try to install stuf themselves
LOL. Yeah True, anything is possible
Postby AzN_DrAgoN48 » Mon May 05, 2003 1:19 pm
haha i know i installed everything correctly. all of my friends were amazed "wow can't believe you installed it yourself!!!" it feels better to know you did it and it works. saved 60 bucks too
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
