SolaraGuy.com • View topic - changes the stereo system
Postby hazee » Fri Nov 09, 2007 3:34 am
Hi there,
I am new here but I need you guys help. I have a 2000 2000 Solara. I am trying to change its stereo system. I saw a nice double-din Kenwood stereo in Bestbuy. However, my car has 8 speakers and the Kenwood system only could drives 4 speakers with 50W for each speaker.
Could you I use it in my car? If so, I will buy it tomorrow.
Thank you so much
hazee
Postby tito53 » Fri Nov 09, 2007 3:51 am
in the yearrrr 2000 2000
tito53
Postby NeFaRiOuS_SLE » Fri Nov 09, 2007 6:56 pm
^LOL!
No, it's Toyota's fancy way of advertising that it has 2 tweeters, 2 fronts and 2 2-way speakers in the back if I'm not mistaken (the only logical explanation that I can think of), so you technically have 6. Still, it's optimized for 4, but usually the front speakers and tweeters are wired on the same circuit, which also stands true for luxury cars with 13 physical speakers.
Postby hazee » Fri Nov 09, 2007 8:51 pm
Thank you guys.
I did a lot of research on it. I think my car has TWO amps, how could I bypass the JBL amp? I can't find the wire connection examples.....
Could you tell me how to connect those wires?
Thank you so so so much..... Big big hug
hazee
Postby Jakecallun20 » Fri Nov 09, 2007 10:37 pm
Welcome, you should introduce yourself in the intro section.
As far as your amp bypass issue, there is a tutorial on that. Just search for these things. 8)
http://www.solaraguy.org/viewtopic.php? ... jbl+bypass
Postby hazee » Fri Nov 09, 2007 11:07 pm
Jakecallun20, Thank you so much :p
I saw this topic beforw, however, these links are DEAD T_T
http://www.cardomain.com/item/SCOTA02B?vq_id=none
and
http://www.cardomain.com/shop/item.pl?sku=SOUIECHUK
I still have no idea ... how to connect the wires...
OMG...
hazee
Postby redgen1 » Fri Nov 09, 2007 11:15 pm
match the colors, youll be aight.
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby Jakecallun20 » Fri Nov 09, 2007 11:24 pm
Yeah, just get some wire caps and connect them to each other. (IE: Red to red) One important thing to remember is the stripes on the wires. Like the grey wires have a black stripe on them. Be sure to match the single wire color to the other and the one with the stripe to the other. This is to differentiate between negative and positive. This all will make more sense when you are actually doing it. Hope that helps too.
Postby hazee » Sat Nov 10, 2007 1:06 am
Thank you so much
I'll try to connect those wires tomorrow :p
hazee
