SolaraGuy.com • View topic - Capacitator Charging?
Postby Blaze » Mon May 19, 2003 2:19 pm
Does anyone know how to charge up a capacitator? Ive lost the little charge thingie, but I know theres another way. I think i need to get a resistor or something. Gunman you should know?
Imagination is the hood ornament on the car of creativity.
Blaze
Postby Yanks0114 » Mon May 19, 2003 3:23 pm
You can use a resistor but the easiest way is a lightbulb.
Re: Capacitator Charging?
Postby pro956 » Mon May 19, 2003 6:39 pm
Blaze wrote:Does anyone know how to charge up a capacitator? Ive lost the little charge thingie, but I know theres another way. I think i need to get a resistor or something. Gunman you should know?
i think (it's been a while):
pos on your battery to pos on your cap
ground your neg
keep it like that for about 30-45 seconds, that should be enough
AIM: pro956
2002 5-speed se v6
pro956
Postby Gunman » Mon May 19, 2003 7:53 pm
different brand caps use different resistor values, but basically what you want to do is put the resistor in line connecting the two terminals, and then connect your pos and neg. Using a multimeter, set it to DC and when it reached 12volts your good. I would think a 1k resistor will be ok, the higher the longer it would take thats all. :wink:
Gunman
