SolaraGuy.com • View topic - HELP! Gen 1 Amp cable!
Postby Jakecallun20 » Sat Jan 19, 2008 3:54 pm
Where can I run it through? I couldn't for the life of me find a place. I tried on both drivers and passengers side. My friend who was helping me told me I could drill a hole in the floor right in front of the pass. seat (amp going under seat) and run the cable literally under the car to the battery.... but I don't want to do that unless there is absolutely no other way. Please guys, I really need help.
Postby Ransom8707 » Sat Jan 19, 2008 4:17 pm
I had the same problem but heres my post that should clear it up for you no need to drill
http://www.solaraguy.org/viewtopic.php? ... highlight=
Ransom8707
Postby AllShowNoGo » Sat Jan 19, 2008 4:44 pm
If u have a gen 1 i would suggest you drill a whole through the driver side firewall. I found a great spot that looks as thought it was already a hole then filled with sheet metal. Ill try to get a pic for u tomorrow.
I found the driver side easier since u have to use less wire.
AllShowNoGo
Postby Jakecallun20 » Sat Jan 19, 2008 4:59 pm
Thanks, I found that link very helpful. I am going to go look at that spot that unbalanced pointed out.
Postby Jakecallun20 » Sat Jan 19, 2008 6:58 pm
alright. I couldnt find that thread in search.. :( anyways. I ran the cable thru the grommet with the big hose on the pass. side of car. Worked out great, got it all ran and is now ready for the amp.
in the engine bay:
behind the glove box, inside the car:
cable inside car:
Reason for so many pics....: new camera :D
Postby DrLove » Sun Jan 20, 2008 7:07 pm
I need to do the same soon as I can (too cold outside here) ..so I wanna ask you Jakecallun20, do you need to remove the glove box ?
Mazda 6 2010 6 speed black GS
DrLove
Postby Jakecallun20 » Sun Jan 20, 2008 7:10 pm
yeah. you gotta remove the glove box, the black piece connected to the bottom of it, the trim along the door and possibly the fuse cover down on the left. It'll all make sense when you get in there. Good luck and let me know if you need more help.
Postby Ransom8707 » Sun Jan 20, 2008 7:13 pm
DrLove wrote:I need to do the same soon as I can (too cold outside here) ..so I wanna ask you Jakecallun20, do you need to remove the glove box ?
well personally i did and i would suggest you do so you can have a clear view into the inside of the dash where the hole will be...its very easy couple of screws you need to take unscrew
i actually ran my 0/1 gauge cable through there i was thinking about drilling but decided to go this way and it turned out to be a great easy way
Ransom8707
Postby Jakecallun20 » Sun Jan 20, 2008 7:31 pm
Yeah. I'm glad I found it before my friend convinced me that I had to drill!
Re: HELP! Gen 1 Amp cable!
Postby RichD978 » Sun Jan 20, 2008 7:51 pm
Jakecallun20 wrote:My friend who was helping me told me I could drill a hole in the floor right in front of the pass. seat (amp going under seat) and run the cable literally under the car to the battery....
call your friend and tell him RIch D said he is a complete idiot
RichD978
Postby Jakecallun20 » Sun Jan 20, 2008 7:57 pm
I'll do that. 8) :evilbat:
Postby boneezy » Thu Jan 24, 2008 4:43 pm
yeah you dont need to drill for your power line. that rubber grommet wrapping around the steering column is perfectly fine
1999 SE-V6 5spd
160,xxx miles
boneezy
