SolaraGuy.com • View topic - Aftermarket HU in 2000 w/ JBL
Postby TqMnster » Fri Feb 01, 2008 9:32 pm
I've bout had it with this dang car. I've put new headunits in every car/truck i've owned. even my camaro that had a bose amplified system ad it wasnt this bad. how am i supposed to do it?
2000 Solara - Red SLE-V6 w/ Conv. Top
2000 Dodge 2500 - Cummins Turbo Diesel..... Far from stock.....
TqMnster
Postby TqMnster » Fri Feb 01, 2008 9:36 pm
I bought the scosche wiring harness from wally world and plugged that into the two plugs off to the right behind the old unit. no power...... anyone have a wiring diagram? i'll just straight wire it i guess. or if i get too fed up with it just run new wires and leave it alone..........
TqMnster
Postby Jakecallun20 » Fri Feb 01, 2008 10:52 pm
There is an easy way! Up in the right hand corner of the dash opening there is a harness. Pull it apart. The harness you bought will match that harness. It is the factory amp bypass harness. GL with this.
Postby TqMnster » Sat Feb 02, 2008 7:00 am
do i use both connectors? i unplugged those two and plugged them into that and it seems like the small one doesnt go in far enough to snap and the power from those wires wont let the radio turn on?
TqMnster
Postby Jakecallun20 » Sat Feb 02, 2008 8:53 pm
First make sure that the pins inside the connectors line up right so they will touch and then the connector that you bought should plug right into the one that you unplugged in the upper right to bypass.
Postby TqMnster » Sat Feb 02, 2008 9:12 pm
do you unplug both or just the top one?
TqMnster
Postby Jakecallun20 » Sat Feb 02, 2008 9:40 pm
Well. In my car it was 2 harnesses connected together, and I unplugged them and used the one that fit to my aftermarket harness to wire to the HU
Postby TqMnster » Sun Feb 03, 2008 8:58 am
This one has two plug back at the top right of the opening. They both fit in there but the smaqller one doesnt want to plug in all the way?
TqMnster
Postby TqMnster » Sun Feb 03, 2008 8:34 pm
Finally got the radio working!!! Wanted to fight me every step of the way. Holy Crap! Anyways now the accesory wire soenst get any power? is there a seperatre fuse box somewhere or what would be the deal? I did get a spark and had to replace the radio fuse in the box under the hood.
TqMnster
Postby Jakecallun20 » Sun Feb 03, 2008 8:52 pm
Only fuse panels in car are under the hood and the one inside the cab.
Head Unit
Postby Donnie » Tue Feb 19, 2008 12:37 am
My 200 with JBL is considered a 'Premium' unit, but it only used one plug in the back of the stock unit. In order to hook up after market I'm having to get an amplified harness that Circuit City carries, part #70-8112. With this harness I wont have to by-pass the JBL amp that's behind the glove box. There are 15 & 20 pin harness kits. I'm thinking the 20 pin kit is for if you have a factory CD changer and the 15 is for single load kit. I'll find out tomorrow. I just ran into my problems this morning when I tried my install and after hitting every parts store in town they all had the same harness but they were the two plug harness that dosn't work on JBL Premium units. Seems the 'Premium units were originally intended for Lexus, and that's why when you ask a goober at Best Buy or Wally World for a harness kit for your 2000 Solara they dont know any better. Hey I own the car and didn't know. I'm right in the middle of my adventure but I'm picking up the amp'ed harness in the morning. I'll let you know if this takes care of everything and the difference in the 15 & 20 pin sockets. I got most of this info from a couple other SG's, today and thanks again to them.
Donnie
Postby Donnie » Fri Feb 22, 2008 2:55 pm
Well Circuit City didn't have it, even after they told me they did and I drove 1/2 hour to get there. Was driving through Nashville though and saw what looked to be a high end system shop so I stopped in there. They sold me one that had 10 pins and 4 AC plugs that he said I'd have to splice. OK, no big deal, I figure I can do that and I did. Didn't work. So I ordered a 15 pin Lexas/Toyota 1992 to 2003 amped so I dont have to bypass the stock JBL amp harness from Discount Car Stereo.com Looks to be what I need, but after paying 27.00 for a 13.00 part to have it overnighted and the mails ran at my shop and at my house I'm still waiting. Don't mind the wait so bad but, damn I need my mp3 playin, frontload USB brand stankin new unit in my car to be up and running. I'll let ya know what happens.
Donnie
