SolaraGuy.com • View topic - quick decision
quick decision
quick decision
Postby Peter » Thu May 22, 2003 11:26 pm
Im getting the Alpine V12 MRD-M300. is it better to use the alpine 12" 2ohm or 4ohm Type R subwoofer with it? They're both rated at 300w RMS and the amp is at 300w x 1 2ohm 14.4v. im just wondering if i should get the 2 ohm 12" sub or the 4ohm 12" sub.
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby c2g » Fri May 23, 2003 6:03 pm
go for the 2 ohm it can take more than 300 watts rms its says 300 but it will handle more
99 silverstream SE V6 18" RSL nengans, Streetglow head and fog lights, Reverse guages,
Kicker L7 12" DVC, MTX amp, panasonic 903U, sirius, shaved emblems, clear corners,
altezza tails, K&N filter, mesh upper & lower grill so far
c2g
Postby pro956 » Sat May 24, 2003 2:38 pm
c2g wrote:go for the 2 ohm it can take more than 300 watts rms its says 300 but it will handle more
NO!
it will handle more than 300w rms, but it's not recommended. it's rated at 300w rms for a reason... i'm sure you can send it 1000w rms for a tenth of a second and it won't bust, get the idea? anyway, alpine subs aren't that underrated...
anyway, the amp is a mono amp and i'm pretty sure the subs are dvc subs, so do not get the 2ohm model, get the 4ohm model (wire vcs in parallel = 2ohm final impedance)
AIM: pro956
2002 5-speed se v6
pro956
Postby Yanks0114 » Sat May 24, 2003 3:05 pm
If they are DVC get the 4 ohm like pro said above. Wire them like this
Postby Peter » Sun May 25, 2003 4:19 pm
Yanks0114 wrote:If they are DVC get the 4 ohm like pro said above. Wire them like this
so if i wire the 4 ohm dvc like that it'll run at 300rms 2ohm?
Visit Black Sheep
Peter
Postby Yanks0114 » Sun May 25, 2003 4:52 pm
Correct. The subs see 4 ohms, but the amp sees a 2ohm load.
Postby Peter » Mon May 26, 2003 10:34 am
cool, thanks for the help.
Visit Black Sheep
Peter
Postby prophesized » Mon May 26, 2003 12:07 pm
NO!
actually the type R's are pretty inefficient and can take a good bit more than what they are rated at if you know what you are doing
prophesized
Postby c2g » Wed May 28, 2003 9:01 pm
the type r can handle 500 watts rms no problem
c2g
