Building Enclosure
im building my own enclosure soon. its gonna have 1 port tube. should i use polyfill?
- Peter
- Mod Alumni
Peter wrote:im building my own enclosure soon. its gonna have 1 port tube. should i use polyfill?
pro956 wrote:Peter wrote:im building my own enclosure soon. its gonna have 1 port tube. should i use polyfill?
should you use polyfill?
depends
best plan: build the box to spec (manufactures recommendation)-> no need for polyfill
polyfill is *sort of* a fix for enclosures that are too small for a sub
CrazyCraig wrote:pro956 wrote:Peter wrote:im building my own enclosure soon. its gonna have 1 port tube. should i use polyfill?
depends
I disagree. You'll get better sound and performance from your sub by filling your box with loosely packed fiberfill. This is especially true with a vented enclosure.
prophesized wrote:ok for a 1.18 cube box: i dont know what you want to tune it to so i chose 35hz. with a 4" pvc pipe you would have to make it 20.4" long. let me know if you wanna change anything.
