SolaraGuy.com • View topic - Car Audio Question
Car Audio Question
Car Audio Question
Postby DiamondPearlSolara01 » Wed Apr 09, 2008 6:01 pm
I have an after market alpine head unit with infinity speakers all around powered by a four channel amp, and two alpine type r's hooked up to two v12 mono sub amps also everything is running through a capacitor. All of a sudden I get in my car and nothing worked but the head unit. I have no sound at all and I am wondering what could be causing this or has anybody had anything happen like this?
2001 Solara V6 SLE
TRD - K&N - Alpine - Infinity
Postby woa_its_j3ff » Wed Apr 09, 2008 6:15 pm
do you hear static?
is all the wiring done up correctly?
blow a speaker or anything of the sort?
do you hear static/fuzzing??
Postby netherland24 » Wed Apr 09, 2008 6:37 pm
STEP one -----
check too see if you have power light on your amps....
- IF YOU DO then... look intoo your connections...
- IF YOU DO NOT
check fuse under hood.... if that is bad then replace... if good then look at your cap...
00 SS Lara 277hp
05 DODGE RAM 1500 n/a
netherland24
Postby Jakecallun20 » Wed Apr 09, 2008 6:47 pm
when you say nothing worked, do you mean electronics or the entire car. It wouldn't start or anything? Sounds like you've got wires crossed some where, regardless of the severity.
Postby DiamondPearlSolara01 » Thu Apr 10, 2008 5:15 pm
No its weird My head unit works .. all other 'car electronics' work but no power to amps (not lit up) no power to capacitor (tells me its a battery/fuse problem usually) and there is no sound or static coming from any speakers but everything is wired correctly... very confused
2001 Solara V6 SLE
Postby XEusioN » Thu Apr 10, 2008 5:42 pm
Check your remote turn-on lead.
2005 Toyota Tundra SR5 V8
2004 Toyota Solara SE
7.1L - 12 Cylinders :: 442hp/488lb-ft
XEusioN
Postby redgen1 » Tue Apr 15, 2008 6:03 pm
check all tooth fuses in the sides of your amps, your in-line fuse for your main power line and like they said, remote connection - back of the h/u
02 SLE V6
Kaizen *constant improvement*
redgen1
