SolaraGuy.com • View topic - HELP: Alpine MRD-M300
Postby Peter » Wed Jun 04, 2003 7:35 pm
this amp has a lot of settings. im new to these settings/terms and the owners manual doesnt explain these things. i guess they think only pro's are allowed to use these settings or something. can you guys help me out? i need recommendations on how to set this amp up w/ my setup. it'll be running a 10" alpine type r @ 300w rms 2ohm in a 1.18 cubic feet box w/ ported tube.
Crossover Type : 24dB/Octave Low Pass - Digital
Low Pass Crossover Frequency (Selectable) : 30Hz - 200Hz (1/6 oct. Steps or Off)
Number of Time Correction Channels : 1
Parametric EQ "Width" (Selectable) : 1,3 ("Q")
Parametric EQ Frequency (Selectable) : 30 Hz - 160Hz (1/3 Oct. Steps)
Parametric EQ Level (Selectable) : ±10dB (2dB Steps)
Subsonic Filter Range : 15Hz - 50Hz (5Hz Steps) or OFF
Subwoofer Level Adjustment Range (With RUX-4180 or RUX-4280 Connected) : -15dB to 0dB (11 Steps RUX-4280)
Subwoofer Phase Control : Normal (0°) or Reverse (180°)
Time Correction Adjustment Range : 0 - 10 mSec. (0.5mSec. Steps)
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby Gunman » Thu Jun 05, 2003 7:41 pm
Basically what you want to do is set it up kinda
crossover..........digital
low pass filter......30-40 hertz range depending what the box is tuned for
"Q".........keep in on what ever band is considered ''narrow''
EQ level........keep that flat untill runing test music and adj accord to bass
Sub sonic filter .........should always be on about 20 hertz should be good
Phase should be normal 0
and time correction is what the formula will spit out on the web site for bass focus.
that help? I would explain but i would have to send you to school for about a year for you to understant that. :wink:
Gunman
Postby Peter » Fri Jun 06, 2003 11:53 pm
thanks gunman, that helps, i'll email u if i got specific questions about the settings :D
Visit Black Sheep
Peter
Postby pro956 » Sat Jun 07, 2003 7:53 am
Gunman wrote:Basically what you want to do is set it up kinda
really? that low? i tend to keep it a bit higher, you mind going into that a bit more? typically i use sealed boxes
he'll have a fairly steep slow too with 24dB/Octave too. peter does your head unit have a low pass filter?
i'd say mess around with the low pass crossover and leave it where you like it, don't go too high unless you mainly listen to rock-- and i think you said u listened to rap
AIM: pro956
2002 5-speed se v6
pro956
Postby Peter » Sat Jun 07, 2003 11:54 am
yeah, i listen to rap. i'll come back w/ more questions about the settings once i get it all hooked up next weekend.
Visit Black Sheep
Peter
Postby Gunman » Sat Jun 07, 2003 5:19 pm
Yeahs thats where you want you sub bass to hit around, depending on what you listen to most
Gunman
Postby Peter » Tue Jun 17, 2003 2:22 pm
any of these settings change if i go sealed? other than subsonic filter...
Visit Black Sheep
Peter
