SolaraGuy.com • View topic - HELP :: ALPINE HU & BLUETOOTH :: NO DEVICE??
Postby illstylez » Fri May 30, 2008 7:18 pm
Hey its me again :)
I just got a alpine KCA-100BT bluetooth unit. I have an alpine CDA-9885 HU, and a Blackberry 8703e.
The problem is that it shows that the device is paired, and I have BT enabled. The phone picks up the signal and so does the box. But the HU seems keeps saying " No Device " when I press the "Phone" button on the HU.
I also tried using the remote that comes with the KCA-100BT and that dosnt work either.
I have made the device "Trusted" , disabled encryption, made it "Discoverable". Any advice is helpful. Thanks guys.
Kentel " Ill " Styles
Chicago IL,
99' Solara Since 2007
" The best way to predict the future is to create it! "
illstylez
Postby xan16 » Fri May 30, 2008 8:52 pm
I've seen this happen to really old phones with new BT headsets, usually related to incompatible BT versions. Not saying that's the case but is a possibility.
2000 Solara SE V6. Autumn Red Mica
[ Eibach lowering springs | Tokico struts | 17x8 wheels | custom exhaust | tint | etc... ]
xan16
Postby illstylez » Sat May 31, 2008 10:42 am
Bump
Chicago IL,
illstylez
Postby corlon » Sat May 31, 2008 10:52 am
is there a pink/blk wire for mute with the system? if so try hooking them up together from the bt to the hu. i had a problem with a cda9884 and a kce300bt and the mute wire needed to be connected between the 2. let me know.
NiCe
corlon
Postby illstylez » Sat May 31, 2008 2:06 pm
Yeah so I pulled the unit from the dash again and checked all connections. The pnk/blak wires are connected to the HU via the BT Unit. The AI-Net connect also is connected. IM STUMPED
Chicago IL,
illstylez
Postby Aotoyota » Sat May 31, 2008 2:36 pm
cycle the ignition...
turn the bt off on your phone
turn the bt ON on your phone
in the devices, connect to the kca-100bt.
that should do it.
cheers
Aotoyota
Postby corlon » Sat May 31, 2008 4:42 pm
i just went to alpines website. they claim the 9885 works with the kce-300bt, not the 100. ???
NiCe
corlon
Postby illstylez » Sat May 31, 2008 6:42 pm
corlon where did you find that I couldn't find any info on their site but that wak users manual :(
Oh well. Guess I ll have to sell it and see if I can find a KCE 300bt
Chicago IL,
illstylez
Postby corlon » Sat May 31, 2008 10:16 pm
i went to www.alpine-usa.com
select products
then selected headunits
cda-9885
then selected accesories
scroll down to see kce-300bt
NiCe
corlon
