SolaraGuy.com • View topic - Hey Ross - Gunman..
Hey Ross - Gunman..
Hey Ross - Gunman..
Postby Phenom24 » Fri Jun 13, 2003 11:35 am
If I were to attempt to take out my CD changer..
No big deal, or fuhgettaboutit?
I have never done anything even resembling auto audio.
I got a quote from Auto Audio in Neptune City to install my Alpine.
$75! I think when I had my Sony changer put in my last car it was over $100 at Circuit City...
Glenn
Now that I know you I could never turn my back away
Now that I see you I believe no matter what they say
Phenom24
Postby Yanks0114 » Fri Jun 13, 2003 11:40 am
Do you have an aftermarket cd changer? Where is it located?
Should be very easy to remove
What do you plan to do with it after its removed
Postby Phenom24 » Fri Jun 13, 2003 1:47 pm
It's the stock 6-disc one in the dashboard...
I pulled out the ashtray but that was as far as I got.
hehe
(If I manage to get that thing out there is still the problem of getting the CDs out of it though..) :(
Glenn
Phenom24
Postby Gunman » Fri Jun 13, 2003 2:55 pm
is it the alpine with the v drive?
Gunman
Postby Phenom24 » Fri Jun 13, 2003 6:11 pm
Have the 9813 sitting here on the floor. I don't know. (goes to look)
Apparently yes:
V-Drive Hybrid Amplifier: A V-Drive MOSFET power unit is used to boost the incoming voltage from 14.4 volts (approx.) to 17.2 volts. The increased voltage allows the unit to deliver peak output of 60 watts x 4 channels. While providing high power output, this unit can draw a substantial amount of current, so the constant power wire must be connected directly to the positive terminal of the battery in your vehicle. For more info, please see the "Wiring Note" section below.
That means the battery will probably croak in the middle of nowhere.. haha :lol:
Glenn
Phenom24
Postby Gunman » Fri Jun 13, 2003 7:41 pm
ummmmmmmmmmm, a simple yes would have done :wink: but thats normal for that install, just make sure that they do indeed go directly to the battery.
Gunman
Postby Phenom24 » Fri Jun 13, 2003 8:43 pm
Yeah, I'll make sure they run it to the battery.
So back to my original question:
Hard to take out the stock unit (6 disc changer) out of the dash? (and I have to get my cds out of it somehow)
Thanks guys.
Glenn
Phenom24
Postby Yanks0114 » Fri Jun 13, 2003 9:15 pm
Postby Phenom24 » Sat Jun 14, 2003 2:44 am
Thanks guys - doesn't look like too much there... But what about the clips? Should I be looking for all of those to try to free up the trim, like those 8 places I should jab in a little screwdriver or something?
Much appreciated - please understand - for me it's definitely "Car Stereo Removal for DUMMIES"...
Thanks again!!!
Glenn
Phenom24
Postby aleath » Sat Jun 14, 2003 5:23 am
Just be patient when taking the trim off and do not rush. Work your way around the trim pulling it off a little bit each time. I've taken my dash trim off 2 times now and have also removed my a-pillar, drivers side kick panel, door sill trim, rear seat trim on drivers side, etc without ever breaking a clip. Its really not that hard as long as you are careful, patient, and gentle with the trim.
I've never had to use a screwdriver to help in the removal of the dash trim. If you find that you need to or think it may help, be sure to wrap the tip of it in tape so that you do not scratch anything.
Silver 02 Solara SE V6
aleath
Postby Phenom24 » Sun Jun 15, 2003 5:06 pm
I was able to take off the trim!!
Of course now I have to wait until Friday to get the player installed..
Bleh.
Thanks guys!
Glenn
Phenom24
