SolaraGuy.com • View topic - Bypassing the amp
Bypassing the amp
Bypassing the amp
Postby variant » Wed Aug 27, 2008 10:21 pm
Hey guys, I have all JBL speakers and the amp is there by the glovebox but the headunit does not have a JBL logo on it, instead it has Toyota ###### on it ( I forget the number) so I'm not sure if this is a "JBL System" but whatever. Anyways, I opened the thing up to put in a new head unit and there is no second harness set like everyone has been saying, I just have one going in to the 20 pin slot and the antenna one.
So does anyone have a tutorial on bypassing the amp?
I've been w/o music too long :evil:
variant
Postby bassthrive » Thu Aug 28, 2008 8:28 pm
The harness for bypass is hidden on the inner right side of where your old headunit used to live. Inner meaning close to the dashboard surface, not towards the firewall. You will see two white plugs attached to each other. Unclip them.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby TLMNICK » Thu Aug 28, 2008 8:34 pm
Right behind the radio, toward your right, you'll see two harnesses mounted off to the side. One harness will be smaller than the other with the wire colours Pink, purple, light green, and blue.....the other harness will be slightly larger with more wires, including a white and red one...I'd post a pic if i had one, but I dont.
TLMNICK
Postby variant » Sat Aug 30, 2008 11:59 am
Alright, I got time to burn today so I'll check it out, so this extra pre wired harness needs nothing else? I just plug in the new head unit and am good to go?
edit: also is there any tutorial w/ pictures on doing this? I've never done anything like this before.
variant
