SolaraGuy.com • View topic - excess static when defrost on
Postby solara90 » Thu Nov 27, 2008 10:41 am
when im listening to the radio and if i turn my rear defrost on all can get is static out of my radio, i got a JVC head deck. So it must be interfering with the antenna, but how would i go about fixing that?
02 solara 2az
solara90
Postby Aotoyota » Sun Nov 30, 2008 10:30 am
try regrounding at the Headunit. or if you have an ant amplifier, maybe the ground on that is loose.
Aotoyota
Postby solara90 » Sun Nov 30, 2008 1:00 pm
ok, ill try that and see if it works, thanks
02 solara 2az
solara90
Postby wekillyou » Fri Feb 13, 2009 12:02 am
same thing happens to me to and I have all factory stuff...
wekillyou
Postby Ilovemylara » Fri Feb 13, 2009 12:13 am
I have the same problem, only I have a stock headunit...
