SolaraGuy.com • View topic - us acoustics amp problem
Postby kronos98 » Sun Jun 29, 2003 2:27 pm
i'm having a major heartbreak guys. i installed my system a few weeks ago and had absolutely no problems.
however, i had some time this weekend, so i wanted to make the wire installation more "professional" so i tucked it behind the panel next to the rear seat. i saw a wire being grounded there (very thin), so i decided to move my ground there. before, it had been electrical taped to the mounting screw of my rear deck speakers.
everything was fine, until i noticed that i'd developed some engine noise. so i opened up the panel again. and while i was messing around and navigated the wires through my car, i noticed that the amp stopped working.
when i was messing around, everything was unplugged: fuse and power to the amp. when i hooked it all up again, the amp was dead. it wouldn't power up! do you guys know what the problem might be? do you think i fried it? or maybe it got bumped around too much? there is a green power light that comes on when voltage is passed to the remote on lead, but that doesn't even come on. someone please help!!
kronos98
Postby kronos98 » Wed Jul 02, 2003 6:49 am
ok, now i've got a totally different problem with my amp. sometimes it works, sometimes it doesn't.
when i give juice to the remote on lead, the amp power light will come on halfway, then fade out. sometimes, i also get a pop sound.
is my amp just fu**ed up? and i shouldn't waste my money on ebay?
kronos98
Postby Blaze » Wed Jul 02, 2003 7:38 am
the us acoustics amps are weird, see if its overheating, also try unplugging ur negative terminal for a few mins, i had the same problem w/ it not turning on had to disconnect the terminal and it came back on after
Imagination is the hood ornament on the car of creativity.
Blaze
Postby kronos98 » Wed Jul 02, 2003 1:59 pm
yeah, if i turn it off for a while, then it'll turn on. is there anything that us acoustics will do for me? this is such an annoying problem...grr!!
kronos98
Postby kubi » Wed Jul 02, 2003 2:42 pm
Are you sure your ground is .... grounded well? Make sure it's not coming loose or anything, especially if it's behind the seat or something, a place where it could move when you move the seat.
kubi
Postby kronos98 » Fri Jul 04, 2003 11:48 pm
i know it's grounded ok, b/c i unscrewed the ground. a few mintutes later, i screwed it back on. worked fine for a short while...then died again until i unplugged it and plugged it back in again. so annoying. is there anything i can do to fix this? or should i sell it back on ebay and get a different amp? i would really like to keep the one i have right now and just fix the problem.
kronos98
