SolaraGuy.com • View topic - Good Ground Location on Gen1?
Postby hari-bhari » Fri Feb 06, 2009 9:14 am
I need a good grounding location for the main ground wire for my amp. Right now it's on the right side vertical wall, about halfway back in the trunk. I screwed into an existing hole that was there. I obviously sanded the surface. But the metal seems like sort of a thin plate so I'm wondering if I'm not getting as good conductance as I could. Where else have y'all grounded?
hari-bhari
Postby indiglosolara » Fri Feb 06, 2009 10:17 am
under your rear seats.. use the seat belt bolts....
Thats where I ran my grounds...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby hari-bhari » Fri Feb 06, 2009 10:20 am
NICE! im gonna try that out and see if it helps. i feel like not enough of my charge is getting back to my battery....
hari-bhari
Postby Toy1mzfe » Fri Feb 06, 2009 4:55 pm
Yup thats the best spot i used. Its good and hidden.
Postby Chewie » Wed Mar 18, 2009 2:08 pm
There is a nice spot in the trunk on the right side towards the back seats as well where Toyota has grounded other things already, I used this and it has worked well so far.
Chewie
Postby illstylez » Wed Mar 18, 2009 2:11 pm
I agree with Chewie. I grounded mine on the right side towards the back seat behind the carpeting. Great ground for me.
Kentel " Ill " Styles
Chicago IL,
99' Solara Since 2007
" The best way to predict the future is to create it! "
illstylez
Postby Ilovemylara » Wed Mar 18, 2009 2:28 pm
i persnally drilled a hole just below my amp in the floor of the trunk, that may my ground wire would be shorter, the longer the wire, the more electrical current resistance
Postby corlon » Wed Mar 18, 2009 11:22 pm
usually any existing bolt hole will have resistence. at least 5 ohms or more. test in with a meter. you'll be surprised. i would make my on ground.
NiCe
corlon
Postby D-money » Thu Mar 19, 2009 2:02 am
I used seat belt bolt
D-money
