SolaraGuy.com • View topic - installing aftermarket stereo
Postby zelahi » Wed May 27, 2009 10:42 pm
hi just curious i got the upgraded jbl sound system. I have two subs, one amp, and four speakers, unless those two small speakers have a different wire. I was wondering how many channels do I need so I could run an aftermarket stereo would a 4 channel work or do I need a 6 channel
1999 Toyota Solara- TRD Short Shift, TRD Rear and Frotn sway bar, and TRD Strut car, Stage 3 body kit and 12k HIDS.
Coming soon: Weapon R Dragon Intake, Custom exhaust or TRD Exhaust, and custom hood
zelahi
Postby corlon » Wed May 27, 2009 11:32 pm
do you plan on running the factory amplifier with an aftermarket deck, or do you want bypass the factory amp?
NiCe
corlon
Postby zelahi » Sat May 30, 2009 11:12 am
i was hoping to use the factory amp through the deck. I got a aftermarket stereo currently installed but the volume button is stuck so it doesnt go any higher or lower
zelahi
Postby yaddadaimsayin » Sat May 30, 2009 11:32 am
zelahi wrote:i was hoping to use the factory amp through the deck. I got a aftermarket stereo currently installed but the volume button is stuck so it doesnt go any higher or lower
LOL!! kinda defeats the purpose then don't it?
Postby zelahi » Sat May 30, 2009 1:46 pm
but i got two subs and I hooked them up to the amp i was hoping to go through that
zelahi
Postby D-money » Sat May 30, 2009 2:12 pm
D-money
Postby zelahi » Sat May 30, 2009 6:22 pm
sry still kinda confused after reading it. I get that i should bypass the stock amp but do I need to buy an aftermarket amp to replace it
zelahi
Postby TLMNICK » Sat May 30, 2009 7:01 pm
You don't HAVE to bypass the amp, but it would sound lots better if you did.
TLMNICK
Postby D-money » Sat May 30, 2009 7:40 pm
you will need an amp to power your subs
D-money
Postby zelahi » Sat May 30, 2009 8:18 pm
alrite wats a good amp to invest in that cheap
zelahi
Postby D-money » Sat May 30, 2009 8:22 pm
what are specs on your subs?
D-money
Postby D-money » Sat May 30, 2009 8:25 pm
the type of hu you need is one with 50w x4 channel with a pre amp out put to signal your subs
D-money
Postby zelahi » Sun May 31, 2009 1:35 pm
alrite thanks ill look for one with that.
zelahi
Postby corlon » Sun May 31, 2009 10:54 pm
we still need the specs on your subs and box type.
NiCe
corlon
Users browsing this forum: Google [Bot] and 39 guests
