SolaraGuy.com • View topic - JVC in dash dvd lcd went dark...
Postby hskrsolara » Tue Jul 14, 2009 10:33 pm
Hey guys,
So, the display on my double din JVC AVX706 dvd headunit suddenly quit working. In direct sunlight, I can see faint images on the screen, but when the cabin lights are dim you can't see anything. Makes me think that the backlight in the LCD screen died. I took it into Geek Squad, they couldn't fix it. Called JVC, they said they need $65 just to look at it, I would have to send it in, probably take a month to fix, and they would probably charge me for a whole new LCD screen ($500+!!!) What should I do? Anyone have a hookup to fix LCD's for in dash dvd players? The rest of the functions work great, but somehow the display is shot.
If it's a lost cause, I will probably be buying a Pioneer 4100DVD. This really sucks cause I don't even drive the car that much, but I really enjoy having the dvd capability. Any other recommendations for reasonably priced DVD in dash double din units?
hskrsolara
Postby yaddadaimsayin » Wed Jul 15, 2009 12:15 pm
Everything still works though right? The LCD screen on my 04 accord went out (but it wasn't aftermarket). I took it to the shop and they said it wasn't the bulb, but rather the circuit board, which i had to get replaced. Electronics isn't my forte, so good luck!
Postby Ilovemylara » Wed Jul 15, 2009 2:27 pm
Most lcd displays are backlight using a cold cathode tube (bulb, if you must) that is powered by an inverter, similar to that of our reverse glow gauges. You can easily repair that screen using this guide: http://www.inventgeek.com/Projects/Back ... page4.aspx
It is relativly easy, as long as u have a soldering iron.
Postby hskrsolara » Wed Jul 15, 2009 9:25 pm
well, I took it apart and found a L shaped tube. The inverter is hardwired into the circuit board. I think I'm screwed. Thanks for the help though, we gave it a try.
hskrsolara
Postby Dawgz » Wed Jul 15, 2009 9:49 pm
hskrsolara wrote:well, I took it apart and found a L shaped tube. The inverter is hardwired into the circuit board. I think I'm screwed. Thanks for the help though, we gave it a try.
Can you get a pic of the tube and the board its on?
Postby hskrsolara » Wed Jul 15, 2009 10:08 pm
You have any ideas Vic?
hskrsolara
