SolaraGuy.com • View topic - Looking 4 Dimensions
Postby hecarmaldonado » Fri Jul 17, 2009 12:24 pm
I want to upgrade my 2000 sle thinking of cd/dvd/gps head unit want the factory look so i need dimension of factory radio cant find it any where! sorry guys need ur help....
hecarmaldonado
Postby ~SolaRaSpeed~ » Fri Jul 17, 2009 4:33 pm
are you asking it is a double-din, because it is a double-din. If your asking about height or width, then I would just measure (but I'm pretty sure a double-din is what you are looking for)
~SolaRaSpeed~
Postby indiglosolara » Fri Jul 17, 2009 4:57 pm
any standard double din unit would work...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby hecarmaldonado » Wed Jul 22, 2009 8:41 am
so i can get any any 7" touch screen unit?
hecarmaldonado
Postby xJeTx » Wed Jul 22, 2009 10:30 am
^ Correct. Just look for "double DIN" when shopping, cause that's the size you need to fill out the factory space. Something like the pioneer AVH-P4100DVD has a 7 inch screen and is double DIN, so that, or something similar should work.
edit* you can also go to http://www.crutchfield.com/index.html, click on car A/V and GPS -> then "outfit my car" from the submenu and enter information about your car. It will then show you which unit's fit and which do not.
xJeTx
