SolaraGuy.com • View topic - Radio
Radio
Radio
Postby Guest » Sun Jul 20, 2003 8:26 pm
Does anybody know how to take out the stock radio for a 99 Solara V6 SE? pictures would help too. thanx in advance.
Guest
Postby TadS » Sun Jul 20, 2003 9:25 pm
Yeah, it's really easy. You just pop out (yes it just pops out) the black centerpiece. Then there are some screws that hold the radio in. When I say the black centerpiece I mean the whole thing that extends from the clock to the ashtray. You might have to work with it a little to get it out, but it is relatively easy. Sorry no pictures, but you should be able to figure it out :D. Good luck!
TadS
Postby ZXLNT » Mon Jul 21, 2003 9:47 am
Yes the black center trim piece is held in by clips. Take out the ashtray and pull from the bottom. Just keep working it up. It easier if you disconnect the cig lighter wiring and the hazard light wiring. Then 4 bolts and the radio comes out. Its really pretty easy..
ZXLNT
Postby Yanks0114 » Mon Jul 21, 2003 2:40 pm
