SolaraGuy.com • View topic - I think blew the stereo fuse... no clue where to look!!
Postby Inverted » Fri Sep 04, 2009 7:14 pm
Radio #2 fuse under the coinbox (7.5A) was all good, the culprit was Radio #1 fuse in the engine bay (20A)... didn't notice it the first time I looked. Thanks!
Mike
Inverted
Postby ThatVietGuy » Fri Sep 04, 2009 7:21 pm
ThatVietGuy
Postby Inverted » Fri Sep 04, 2009 7:27 pm
Awesome, now how to remove the coin box on the driver's side... guess I'll give that a shot...
Inverted
Postby ThatVietGuy » Fri Sep 04, 2009 7:32 pm
ThatVietGuy
Postby ~SolaRaSpeed~ » Fri Sep 04, 2009 7:44 pm
did you find those with the search function? I didn't even know it could do that...
~SolaRaSpeed~
Postby Inverted » Fri Sep 04, 2009 8:16 pm
UPDATED FIRST POST
Inverted
Postby ThatVietGuy » Fri Sep 04, 2009 10:13 pm
~SolaRaSpeed~ wrote:did you find those with the search function? I didn't even know it could do that...
Yes.
Try using the "Search for all terms" option next time, it gives you a much more accurate search :wink:
ThatVietGuy
Postby ~SolaRaSpeed~ » Fri Sep 04, 2009 10:24 pm
glad you found it and posted your results in fixing the problem
~SolaRaSpeed~
