SolaraGuy.com • View topic - amplifier protection mode
Postby wooshkie90 » Fri Nov 13, 2009 6:59 am
Hey guys. THe amp I just bought yesterday is already giving me problems. I had it working fine for about 5 minutes, then it snaps into protection mode. Ive went through the troubleshooting process and cant figre out whats wrong with it. When I turn theamp on, I see the green light flash, but immediately goes to the red light. Has anyone ever had this problem?? Or does anyone know wht mey be causing this??
wooshkie90
Postby 1gSE » Fri Nov 13, 2009 8:07 am
check your input and output speaker wires
Solara-M62 @ 5.5psi
1gSE
i did that
Postby wooshkie90 » Fri Nov 13, 2009 8:19 am
but its the same problem. I followed instructions i found online and still nothing. I redid all the wiring to make sure everythings secure. All connections are correct.
wooshkie90
Postby MisterTedster » Fri Nov 13, 2009 9:33 am
Perhaps you can tell us what amp it is, what it's driving and the headunit that's feeding it?
MisterTedster
Postby Pogs » Fri Nov 13, 2009 1:27 pm
and perhaps check your gain levels and I dont know how much you know about basic audio installation but you are using an inline fuse for the pos cable right
Search and Win
Pogs
Postby MisterTedster » Fri Nov 13, 2009 3:34 pm
^^^ I agree with Pogs, it could be that your amp is clipping. You can adjust gain levels by setting it to the lowest setting possible, then turn up the volume on the head unit to near maximum. You then slowly turn up the gain until it's as loud as you're ever gonna listen to your music, or until your speakers start distorting, whichever comes first.
MisterTedster
thx all
Postby wooshkie90 » Fri Nov 13, 2009 4:06 pm
Hey, thanx for all the feedback. but it turns out i had a defective amp in the first place, so they replaced it today, and now everythings back to working condition. thx 4 all the info tho, ill keep it in mind if i run into any problems. now that it bumps how i want it to, i gota look into gittn some soundproofin on these doors and the trunk.lol, o and rear speakers while im at it.
wooshkie90
