SolaraGuy.com • View topic - How to remove door handle trim
Postby vSolara » Mon May 24, 2010 2:47 pm
Hello. I blew my factory door speakers out and I'm trying to get my door panel off the replace them. I followed crutchfield instructions, but I can't get the trim that goes around the handle/lock off. I keep prying and prying, and all I've managed to do is scrape up the side of the trim. Is there a trick to getting this off? Thanks!
2001 Toyota Solara SLE V6 - Tinted Windows, Pioneer DEH-2100IB, Pioneer Door Speakers, Custom DIN voltmeter/switchboard, interior accent LED strips
vSolara
Re: How to remove door handle trim
Postby mig0s » Mon May 24, 2010 7:35 pm
Hey, I've had this problem before. There's a little square in the middle, you have to pop it up and you'll see a screw. Once the screw is unscrewed, put a flat head screwdriver (tape it to prevent scratching) between the lock and the upper trim and pull the screw driver down, you'll pop up the trim a little bit. Then pop the lower part and you're done. Hope this helps.
mig0s
Postby vSolara » Fri May 28, 2010 7:58 am
Thanks a lot for the advice, I finally got it off! What a terrible design. That trim is going to stay off until I get the speakers next week.
vSolara
