SolaraGuy.com • View topic - Subwoofer underneath driver's seat
Postby hari-bhari » Thu Oct 07, 2010 11:48 am
I rode in my friend's 335i and I really liked the feeling of bass you get from having the sub underneath the seat. I was wondering if this was possible to do in our cars? A quick google search revealed some 6" subs that go under the seats with the amplifiers included, but I already have an amp in the trunk so all I need is a sub with enclosure to slide under the seat. Any ideas?
hari-bhari
Re: Subwoofer underneath driver's seat
Postby corlon » Thu Oct 07, 2010 8:54 pm
don't really see it happening with a power seat.
NiCe
corlon
Postby MisterTedster » Sun Oct 10, 2010 10:33 pm
If you want the feeling of bass in your seat, buy an Aura Pro Bass Shaker. Not many folks use it for car audio, but it can be done easily.
02 SE V6
MisterTedster
Postby GzNutz » Tue Oct 12, 2010 6:21 pm
I know someone did the bass under the front seats with a gen2 on here, just can't locate the post.
Postby indiglosolara » Thu Oct 14, 2010 1:40 pm
I have subs installed under my front passenger seat on my xb... but there is not enough room on the solara. I have 2 10" Shallow mt. subs at home from elemental Designs. SQ10 subs. It only needs 3" mounting dept. I also have seen the 6" ones which require about 2.5" of mounting dept. Elemental designs has some really good speakers.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby timbrinosa » Sat Jul 16, 2011 10:13 pm
It's possible, but i think you'll need a sub with a built in amps because most probably the amps you have are designed to the current load you have and beside it, having a a dedicated for the sub underneath your seat will assure you maximized power of your sub. :D
I am 30, male and i love cars and bikes.
timbrinosa
Postby dkertis10 » Sat Jul 23, 2011 4:32 pm
MisterTedster wrote:If you want the feeling of bass in your seat, buy an Aura Pro Bass Shaker. Not many folks use it for car audio, but it can be done easily.
can you go into more detail how to hook these up? I've seen them mentioned but never knew how they worked
Kicker sound system, 17 inch MB Wheels on Continental ContiExtremeContact tires, more mods to come..
dkertis10
Postby Budd81 » Sat Jul 23, 2011 4:52 pm
Just like hooking up a speaker. . mount it to the seat & run the wire
99 Camry V6 5-speed S/C'd
Budd81
