SolaraGuy.com • View topic - 2.. amps
2.. amps
2.. amps
Postby Callen » Tue Aug 26, 2003 10:20 pm
Well, as I said in the topic,,, I got 2 amps and 1 sub. They are as follow.
Audiobahn A4401x 240 rms (4 channels)
Audiobahn A1801q 400 rms (mono)
Audiobahn Abb121Q 400 rms 12" enclosure w/sub.
I plan on hooking the 4 channel up to my rear and front speakers, but am not sure exactly how to replace the 6.5's or tweeters. Can anybody shed some light on the subject, or supply some pictures for some good-old-fassioned appreciation?
2 JL 12w6's powered by
Hifonics BX1000D amp@ 1.5 ohms run off an
Alpine CDA-9833
soon to be
CDT EF61CFi/25 6.5" components.
Callen
Postby HKSV6SLE » Tue Aug 26, 2003 10:42 pm
i mnust got my 6.5's in the door changed...out....those should be easy to replace...a good way to upgrad the doors..are to get a component system...that has replacement 6.5's and new tweeters...that way you can do it all at once when the doors are taken aapart...i just got rockford fosgate componenets..for my doors...and for my rear deck...whcih is a pain to take apart...
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby HKSV6SLE » Tue Aug 26, 2003 10:43 pm
i just got...my spelling sucks sorry....
www.lexusnet.com
HKSV6SLE
Postby Callen » Tue Aug 26, 2003 10:46 pm
how about,, Dare i say.... :o :oops: :o :oops: :o infinity's??
Alpine CDA-9833
soon to be
Callen
Postby happy_aggies » Wed Aug 27, 2003 6:56 am
Yup, the front speakers is not really hard to install.
Just remove the door panel.
wiring takes a while tho.. since you gotta push the speaker cable tru the rubber thingy.
happy_aggies
Postby Callen » Wed Aug 27, 2003 8:32 am
Thankyou for you input. I now know that this is not a task too hard for me to have accomplished. My only troubles are as follows...
I don't know how to take off the door panel, and am not familiar with getting the wires to where they need to go.
Thankyou.
Alpine CDA-9833
soon to be
Callen
Postby ZapmanSQ » Wed Aug 27, 2003 10:34 am
HKSV6SLE wrote:i mnust got my 6.5's in the door changed...out....those should be easy to replace...a good way to upgrad the doors..are to get a component system...that has replacement 6.5's and new tweeters...that way you can do it all at once when the doors are taken aapart...i just got rockford fosgate componenets..for my doors...and for my rear deck...whcih is a pain to take apart...
huh, i thought 6x9 in the back would be easy install than 6.5" front!
ZapmanSQ
Postby happy_aggies » Wed Aug 27, 2003 10:56 am
I'll post sumtime next week abt step by step door panel removal. :fadein:
happy_aggies
Postby Yanks0114 » Wed Aug 27, 2003 11:01 am
In order to change the rear speakers you must literally remove the entire back seat. The rear deck is a pain
Postby Callen » Wed Aug 27, 2003 12:13 pm
Yeah, well before my solara, i had a '96 camry, and boy am i familiar with taking out the rear deck.
Alpine CDA-9833
soon to be
Callen
Postby Callen » Wed Aug 27, 2003 12:19 pm
:bad-words: :x :drinking: :bad-words: :2gunfire: ___________ 8)
"Audiobahns suck!!" _________________"No you suck!"
Alpine CDA-9833
soon to be
Callen
Postby HKSV6SLE » Wed Aug 27, 2003 12:39 pm
ok all i have to say about the rear deck is that to take them out ,the seats and all the panels in the back have to come out...so it is a time consuming process..it's not drop out and put in..like on some hondas...i was going to do it myself...but when i got hooked up for the install..i said...do it...but the guy who did it 4 me...took him a few hours to do...so...and he had done other solaras b4..so...that just says a lot...
www.lexusnet.com
HKSV6SLE
Postby swimshady906 » Wed Aug 27, 2003 4:02 pm
the front door panels are relatively easy, just becareful because if it doesn't come easily, then something is still holding it in.
1. inside the handle cup, there is a tiny square that needs to be opened by prying from the side nearest the end of the handle. inside this there is a black screw. remove it.
2. inside the door pocket there is a felt like peice which hides a screw underneath, remove it as well. then pull out this pocket from the side closest to rear of the car ( there is a tip that sticks into the other side of the door)
3. behind this there should be a large gold screw. you know what to do with it.
4. on the very bottom of the interior door padding there are 2 bolts which can be removed by socket or screw.
5. the handle cup must be pulled out before pulling the rest of the panel. pry up the top and bottom of this cup nearest the stem of the handle, open the handle, and then pull the cup toward the rear of the car and slightly out to remove the cup.
6. from here, more or less just pop the panel off by pulling out bottom to top, and once u have freed all the clip things inside just pull the panel up.
I tihnk that about covers it. good luck.
02' S2000 Silverstone
swimshady906
