SolaraGuy.com • View topic - Stereo buying advice.
Postby 505solaraguy » Fri Apr 01, 2011 4:31 pm
hey i was wondreing what is a good stereo for my 2000 solara slv with the upgraded jbl system. i need a stereo that will fit good in the existing space and something that will be easy to install. im also looking for a stereo with direct amp outputs so i can plug my 700 wats dual amp into it. links will be very appreciated
505solaraguy
Re: Stereo buying advice.
Postby enz1ey » Tue Sep 27, 2011 9:42 pm
Any double-DIN radio that suits your needs/wants. There are many out there, but I would go to crutchfield.com to find it. And most, if not all aftermarket head units come with RCA outputs. Newer ones typically have multiple outputs. But if you are iffy about getting something like a GPS enabled head unit, you might want to get one that is "GPS ready," as you'll be able to purchase the needed module down the road if you see fit, rather than buying a whole new head unit. But definitely go with a touchscreen ;)
enz1ey
