SolaraGuy.com • View topic - Getting Subs HELP!
Getting Subs HELP!
Getting Subs HELP!
Postby KingKevin » Sun Apr 03, 2011 6:28 pm
Hi,
I just recently purchased a 2001 Solara. I want to put subs in it. I really dont know anything about audio stuff. What I do know is that I need a new headunit and amp and then the subs.
Can you guys help me find a decent setup for a real tight budget. Im not looking to spend more than $600. If thats not enough to get a decent system, what would you guys recommend I should get if i want to play my ipod in my car.
Thanks in advance
2001 SE V6
Injen intake w/ extension - Renova Grill - custom catback exhaust - 2 12" Kenwood subs - Tein s tech - neons - 8000k headlights - 3000k fogs
KingKevin
Re: Getting Subs HELP!
Postby blackedout » Thu Apr 07, 2011 2:19 pm
I would check on amazon to get good deals on that stuff. I got 2 12s and an amp in a set for 220 there (was worth at least 600 for exact same stuff at best buy) and I got my deck from a frien but they has good deals there on those too. Make sure the output is high on the deck. I upgraded from a 45 watt to 200 watt deck and makes a huge difference.
Hope this helps some!
2000 solara black, 18's custom paint, green HIDs, blacked out lights, 20% all around, 2 12" kenwoods
blackedout
Postby MisterTedster » Tue May 17, 2011 7:28 pm
You'd probably want to browse some car audio forums, caraudioclassifieds.org and diymobileaudio.com are good places to start. No offense to blackedout, but I would ignore the advice he just gave you.
02 SE V6
MisterTedster
Postby KingKevin » Tue May 17, 2011 7:38 pm
ha dont worry about it I alread got them... i got 2 12" kenwoods with a 1800 peak watt amp (500 RMS) plus headunit and all the wiring for under $500
2001 SE V6
KingKevin
