SolaraGuy.com • View topic - Aftermarket rear speakers
Postby S.Z.-Alpha » Wed Apr 20, 2011 5:15 pm
I need some help on how to buy rear speakers. I got 2 issues. #1 is power. I cant upgrade my whole system just yet cuz it's too dang expensive.
Is there a limit of wattage that the stock amp can do? I dont want the stock amp to blow up O_o. What wattage of speakers can I only get? 200 to 300?
2000 Toyota Solara a.k.a "Goldie" SLE V6 //PARTS: TRD Muffler w/ Stock pipes, K&N filter, Tokico Blue Shocks w/ Stock Springs, Kenwood H/U with x4 JVC speakers(250x2 Front and 290x2 Rear) w/ JL 1000 watt amp.
S.Z.-Alpha
Re: Aftermarket rear speakers
Postby yaddadaimsayin » Wed Apr 20, 2011 5:17 pm
dude this sounds just like your last 3 threads
Postby S.Z.-Alpha » Wed Apr 20, 2011 5:18 pm
yaddadaimsayin wrote:dude this sounds just like your last 3 threads
I know I'm gonna delete the others. I already did. I think i was looking at the wrong forum.
Anyway...can you help? T_T
S.Z.-Alpha
Postby yaddadaimsayin » Wed Apr 20, 2011 5:45 pm
can't help you there, since I had my whole setup professionally installed all at once...
but I can help you post in the right section:
viewforum.php?f=13
this is the section for audio upgrades. I did a quick search in there and it seems like a lot of your questions can be answered there.
Postby 99BlackSandv6 » Fri Apr 22, 2011 7:16 pm
Go by what it says in the other threads. For real man... viewtopic.php?f=13&t=51175
call these guys... http://www.crutchfield.com/
Postby enz1ey » Tue Sep 27, 2011 9:37 pm
You can't really "blow up" your stock amp if you buy bigger/better speakers. The speakers might be able to handle more max/RMS wattage, but your stock head unit probably only provides 30-45 watts per speaker RMS. You should worry about the new speakers being under-powered, if anything. Ideally, you'd want to get a new amp to power your new speakers to get the most performance out of them, but you need to be careful not to get too powerful an amp for the speakers, not the other way around.
enz1ey
