SolaraGuy.com • View topic - stock JBL headunit sounds very weak and volume no work
Postby Chhem87 » Tue Jun 21, 2011 8:32 am
So i removed my aftermarket unit from my 2002 sle solara b/c decided to install it in my other vehicle. I then reinstall my OEM JBL 6-disk unit and connected all the wires. now i can even hear anything. Does anyone know what might be causing this? Please help.
Chhem87
Re: stock JBL headunit sounds very weak and volume no work
Postby GzNutz » Tue Jun 21, 2011 6:25 pm
Did you install the aftermarket headunit? If not, the stock amplifier was most likely bypassed. Check to see if its hooked up.
