SolaraGuy.com • View topic - Amp install
Amp install
Amp install
Postby Airwalk1421 » Fri Oct 03, 2003 10:54 am
Can anyone tell me how to install my amp using speaker level inputs??
Airwalk1421
Postby Luc » Fri Oct 03, 2003 8:05 pm
Assuming your amp doesn't have speaker level inputs, what you will need is a high-to-low converter, basically, converting from speaker (high) to RCA (low) levels. Then run the RCA from the converter to the amp.
1998 S/C'd 1MZ-FE A/T
Luc
Postby Airwalk1421 » Sat Oct 04, 2003 7:41 am
ya the amp has speaker level inputs
Airwalk1421
Postby Luc » Sat Oct 04, 2003 7:01 pm
So all you need is tap off the 2 front or rear speaker pair of wires and run that straight into the amp. Then adjust the gain accordingly. Rear is typically much easier since those wires are exposed under the rear deck.
Luc
