SolaraGuy.com • View topic - should i?
should i?
should i?
Postby Peter » Mon Nov 03, 2003 11:55 pm
right now i have the alpine mrd-300 amp powering the alpine type r 10" sub. i wanna upgrade to the 10w7 cuz i can iget it for really cheap. do i need a new amp or will this amp be ok?
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby Luc » Tue Nov 04, 2003 8:10 am
You should be fine with the Alpine amp, of course, feeding the 10W7 with more power is always nice. I suggest go with a slot-ported box like this:
1998 S/C'd 1MZ-FE A/T
Luc
Re: should i?
Postby pro956 » Tue Nov 04, 2003 6:55 pm
Peter wrote:right now i have the alpine mrd-300 amp powering the alpine type r 10" sub. i wanna upgrade to the 10w7 cuz i can iget it for really cheap. do i need a new amp or will this amp be ok?
i'd recommend more power
you could pull if off using the same amp though with the right box (would end up being much bigger than the box u made i think-- you remmember how much making the box cost you?)
what were the specs (cu ft) on the box you made?
AIM: pro956
2002 5-speed se v6
pro956
Postby Peter » Wed Nov 05, 2003 2:32 pm
ill probably make another box if i decide to get it. my box for the alpine was 1.1 cubic feet and it cost me less than 20 to make. also, right now im running 300w rms at 2ohms, i think. the jl is 3 ohm.... is there a special way to wire it to make it 2 or does it not matter? kinda lost.
Visit Black Sheep
Peter
Postby pro956 » Wed Nov 05, 2003 5:09 pm
Peter wrote:ill probably make another box if i decide to get it. my box for the alpine was 1.1 cubic feet and it cost me less than 20 to make. also, right now im running 300w rms at 2ohms, i think. the jl is 3 ohm.... is there a special way to wire it to make it 2 or does it not matter? kinda lost.
woops forgot it's 3ohms, and i have a 12w7 too :p
yeah, u'll need a new amp, u won't get much out of that amp at 3ohms, you cannot change the 3ohm final impedence unless you add a sub...
you could get it bumping with 200/250watts or however much you get out of the amp at 3ohms, but u would need a HUGE box, and it would only produce DEEP bass...
when/if you get a new amp, don't worry if it's only stable at 4ohms, if it's a decent amp, you won't have trouble at 3ohms
AIM: pro956
2002 5-speed se v6
pro956
Postby Peter » Thu Nov 06, 2003 12:36 am
forget that then, ill just keep mine. thanks for the help.
Visit Black Sheep
Peter
Postby ChrYstiE » Sun Nov 09, 2003 12:48 pm
You need 3 and 1/2 of those amps to power that sub. If not, you will underpower it and damage the voice coil.
08 VW GLI
ChrYstiE
Postby pro956 » Sun Nov 09, 2003 1:13 pm
ChrYstiE wrote:You need 3 and 1/2 of those amps to power that sub. If not, you will underpower it and damage the voice coil.
um, no, you could power it with one, adn the vcs would be fine...
it wouldn't take much power to get the sub going freeair
AIM: pro956
2002 5-speed se v6
pro956
