SolaraGuy.com • View topic - What is the "Q-Factor" ?
Postby i20solara02i » Fri Nov 14, 2003 8:44 pm
On my EQ, I can adjust the bass' frequency, gain, and "q-factor"
What's the Q-Factor?
i20solara02i
Postby ZXLNT » Sat Nov 15, 2003 3:32 pm
"Q" is the bandwith or slope adjustment. U pick a center frequency say 50 hz. That is main frequency that will be boosted or cut. With a high "Q" only frequencies very close to the center frequency will boosted or cut. With a lower "Q" a much wide range of frequencies will be affected as well. Think of it as a mountain. The summit is the center freq the slopes are the other freqs. A high "Q" will have steep sides a low "Q" will have long sloping sides..
ZXLNT
Postby Jackass-Jeff » Sun Nov 16, 2003 12:14 pm
Thanks! Now I can adjust our headunits =]
1GR-FE ftw!
Jackass-Jeff
