SolaraGuy.com • View topic - Alpine i-Personalize
Postby Grazi07 » Tue Nov 18, 2003 6:16 pm
Does anyone have experience with this option? Seems like a pretty cool feature, but is it worth the effort? I'm also looking for the distance in between the speakers in the car to set it up. Thanks!
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby HKSV6SLE » Tue Nov 18, 2003 8:40 pm
i think that's like the kenwood soundstage raising thingie...just put a cd in and play with it until the sound is just right...
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Grazi07 » Tue Nov 18, 2003 10:36 pm
see, the trick with this is that you do it online, then save it to a CD and upload it into the headunit, so I'm not sure if you can do it all manually.
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby dmxtw33 » Mon Nov 24, 2003 7:20 am
hey what settings did you set the distance for the 9815. I installed the 9815, but need a lil help setting up the xover, mx, etc. Anyhelp would be appreciate. Thank you.
dmxtw33
Postby impactX » Wed Nov 26, 2003 11:48 pm
You have to measure the distance from your ears to the speakers.
impactX
Postby Grazi07 » Mon Dec 01, 2003 8:49 am
The MX feature is just an ehancement option. You turn it on and it helps strengthen signals to clarify the sound. When I get a minute, I'll measure my stuff out and post the distances.
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
time delay values
Postby ralphredimix » Fri Sep 18, 2009 11:53 am
Here's the values I used for the measurements for the time correction on the Alpine Ipersonalize for my 2000 Solara Gen 1:
Front L : 77CM
Front R: 107CM
Rear L: 135CM
Rear R: 143CM
SUB(in trunk): 150CM (guess.. not sure how delayed the bass value should be)
hope this helps!
ralphredimix
Postby Pogs » Fri Sep 18, 2009 12:02 pm
I hope he still needs the help.... You just resurected a post over 6 years old lmao :lol:
Search and Win
Pogs
