SolaraGuy.com • View topic - Wiring, Fuse Holder
Wiring, Fuse Holder
Wiring, Fuse Holder
Postby jondailey » Sun Nov 30, 2003 5:00 am
Hi, I have been reading these forums for a couple of months. Some stuff I agree with, others I don't. But some people on here seem pretty knowledgable about some stuff.
I did a search and read some of the stuff posted about what I am asking about, but since most of the posts are pretty old most of the links/pics no longer worked. I emailed a few people and got no responses.
So...
Where did all of you all run your power wire? Did you find a workable grommet or did you drill? If you drilled, where at? I am running 1/0awg.
Also, where did you all mount your fuse holder, circuit breaker? I have an ANL fuse holder.
Thanks.
Thanks-
Jon Dailey
Gen-X Audio
jondailey
Postby TadS » Sun Nov 30, 2003 7:14 am
I ran through that rubber thing on the driver’s side of the firewall that the OE wires are run through. There are a big bundle of them, so it's hard to miss. I just cut out an enough that I could ram my 4ga. though and that was that. I have an inline fuse holder and it's zip tied to the base of my battery retainer. Not very showy, but not being able to see it is better than seeing one flopping around under the hood untethered :). A snap-in grommet came with my kit.
TadS
Postby jondailey » Sun Nov 30, 2003 8:33 am
Ill look to see if I can run 1/0 through there then as well. As for the fuse holder, zip tieing it won't be good enough to compete with so Ill have to find a better suited place than that. But thanks for the input.
Thanks-
Jon Dailey
Gen-X Audio
jondailey
Postby kubi » Sun Nov 30, 2003 12:40 pm
I have a circuit breaker mounted right next to the battery screwed to the frame. It's a pain because I have to take it off to replace the driver's side headlight... but don't have to do that often so it's really not a big deal.
Please stop humping my car, owner privilege!
kubi
Postby HKSV6SLE » Sun Nov 30, 2003 1:19 pm
my fuse holder thing is in my trunk, i have a pix of it on my car domain page....
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby ZXLNT » Sun Nov 30, 2003 2:21 pm
I'll go out and take a few pics here in a little while..
ZXLNT
Postby jondailey » Sun Nov 30, 2003 3:00 pm
Thanks for the replies guys. Any pics you all have will help.
HKS...for competition your fuse holder must be mounted no further than 18inches from the battery. This is also for safety sake.
Thanks-
Jon Dailey
Gen-X Audio
jondailey
Postby HKSV6SLE » Sun Nov 30, 2003 3:09 pm
oh wait you said fuse holder, oh yea that's actually mounted above my stock air box, near the battery...thought u meant the fuse distributor thing...
www.lexusnet.com
HKSV6SLE
Postby Peter » Mon Dec 01, 2003 1:05 am
here's some pics. lemme know if u got questions. i ran 0 gauge all the way through, just let me warn you... its a lot of work! took me a whole day to do all the wiring....
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby jondailey » Mon Dec 01, 2003 5:41 am
peter-
is that a factory grommet or a drilled hole? exactly what is your fuse holder mounted too?
Thanks-
Jon Dailey
Gen-X Audio
jondailey
Postby prophesized » Mon Dec 01, 2003 8:31 am
what organization are you going to be competing in?
prophesized
Postby Peter » Mon Dec 01, 2003 12:32 pm
jondailey wrote:peter-
i drilled and bought a rubber grommet. its attached to the battery cover.
Visit Black Sheep
Peter
Postby ZXLNT » Mon Dec 01, 2003 4:33 pm
Peter what did u do with the factory Positive Wire from the car? Did you just cut the end off and connect it to the battery terminal.. I have a dual terminal Red Top the damn terminals are reversed from factor so the factory Pos wire is kind of stretched to make the reach..
ZXLNT
Postby swimshady906 » Tue Dec 02, 2003 2:13 pm
Extend your factory wire with 4 guage or bigger, just get a solid connecter. :D
02' S2000 Silverstone
swimshady906
Postby Peter » Tue Dec 02, 2003 8:28 pm
mine was short too, so i got a new 4 gauge and ran it all the way back to the source. dont splice, its better to run it all the way through w/ a longer 4 gague.
Visit Black Sheep
Peter
