SolaraGuy.com • View topic - Impedence
Impedence
Impedence
Postby Grazi07 » Sat Dec 06, 2003 11:42 pm
My subs (Infinity Reference) are rated at 4 ohms..... what would happen if I ran them at 2? I'm guessing they'd just heat up a lot faster and could shorten the life, but other than that is it an issue?
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby prophesized » Sun Dec 07, 2003 8:57 am
all it would do is give your amp a lower load so the sub would get more power
prophesized
Postby Jon11582 » Sun Dec 07, 2003 10:12 am
From what I know, it depends if you run them in parallel or series.
Under ideal conditions:
Running in series doubles the impedance and halves the power.
Running in parallel doubles the power and halves the impedance.
Youll want to run them in parallel for max power. You would have to make sure that your amp is stable for 2ohm operation, and what the specs say the watt output are at 2ohms would be your new power output. With more poweroutput, your amp will run hotter, so make sure its not in an insulated part of the vehcle and has decent way to give off heat.
Jon11582
Re: Impedence
Postby TadS » Sun Dec 07, 2003 2:18 pm
Grazi07 wrote:My subs (Infinity Reference) are rated at 4 ohms..... what would happen if I ran them at 2? I'm guessing they'd just heat up a lot faster and could shorten the life, but other than that is it an issue?
It won't hurt the subs, but the amp is a different story. Make sure that bad boy is rate 2-ohm mono, or 1-ohm stereo. Also, when you take the amp too lower levels of resistance it gets hotter, so as said above make sure it's mounted in a well-ventilated area, or it'll shutoff all the time in a best-case situation.
TadS
Postby Grazi07 » Sun Dec 07, 2003 6:06 pm
awesome, thanks guys.... I'm thinking of putting them in my trunk, prolly on top of the box I've got.... that safe?
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby swimshady906 » Mon Dec 08, 2003 10:59 pm
Impedence and resistance are different things.... you cant change the subs impedence but you can change the amps load. jfyi...
02' S2000 Silverstone
swimshady906
