SolaraGuy.com • View topic - CAPACITOR vs. EXTRA BATTERY
Postby LOO_SILL » Sat Dec 13, 2003 10:23 pm
I have a nice system in my car but just as any other system, my amp is pulling from my battery causing my lights to flicker. I was thinking about installing a capacitor then a friend told me about the system batteries that they have out. (second battery to supply power to the system) Should I put in an extra battery for my amp or should I go with a capacitor. Any suggestion? and please explain...Thanx.
NO1BLACKMAN
'99 SOLARA SE,BLK
19% smoke tint,factory match woodgrain kit,Pioneer DEH 7500 headunit, JVC component 6 1/2 & 4" x2,MTX 404 AMP pushing,Infinity 6x9 Loudspeaker x2,MTX thunder6000 12" isobaric bandpass,bridged
LOO_SILL
Postby TadS » Sat Dec 13, 2003 10:48 pm
The extra battery is alot more work, but alot more effective. A cap will discharge really fast, so it's not the best option for long duration bass competitions. You could also upgrade the battery under the hood to a yellow top. It’ll give you a lot less headaches, and decent results.
TadS
Postby swimshady906 » Sun Dec 14, 2003 12:17 am
Im pulling a lil over 1650watts rms @ 13.1volts (slowly killing my alt.) with my MTX and iuno say 30 x6 for my alpines and i got 2 Rockford caps... didnt phase the dimming untill i dim the internal lighst and flip my face so the display turns off. Long story short, if you are serious i would go with a more powerful alternator like others have.
Read this , http://www.zer0.info/solaraguy/viewtopi ... alternator
02' S2000 Silverstone
swimshady906
Postby TadS » Sun Dec 14, 2003 12:25 am
I agree that for big time stereos you need the alternator, however if I read right he's only pushing a MTX 404 and deck power. That shouldn't need a beefed up alternator. I have been pushing about 600 watts RMS for the last 3.5 years on all stock stuff. I just updated my battery tonight though b/ the weather was taking a toll on it :).
TadS
Postby HKSV6SLE » Sun Dec 14, 2003 4:56 am
refer to other posts we have argued extensively about this subject, tho a beter battery will def. help.
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby swimshady906 » Sun Dec 14, 2003 10:04 am
Good point TadS.
swimshady906
Postby LOO_SILL » Sun Dec 14, 2003 1:29 pm
I them I am understanding that because of the minor load I currently have, I will be fine with a cap...is that right?
NO1BLACKMAN
'99 SOLARA SE,BLK
LOO_SILL
Postby prophesized » Sun Dec 14, 2003 2:39 pm
no just get a better battery like optima, svr, westco, etc for under your hood
prophesized
