SolaraGuy.com • View topic - Wiring 2 1 farad capacitors??
Postby indiglosolara » Thu Jan 08, 2004 7:57 pm
Ok, Here's what im trying to do. Right now im running a 1 farad digital capacitor, But what im thinking is buying another 1 farad capacitor.
I was wondering how would wire up 2 capacitors?????? anyone have diagrams that i can print out. I will be building my amp rack soon and i wanna do it right the first time. I have gone thru so many systems and i finally got all the right stuff i want now.
Can anyone help????
Thanks
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby MGLax13 » Fri Jan 09, 2004 12:43 am
You can buy these bars that connect the terminals on the caps together. I've seen them around, not sure what they're called. I'm sure you can do the same thing with wire, just wouldn't look as clean. I'll look around for these bars I speak of.
*Edit*:It's called a "capacitor linking buss bar" Here's an example I saw on ebay http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3069486758&category=14932
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby indiglosolara » Fri Jan 09, 2004 1:30 am
MGLax13 wrote:You can buy these bars that connect the terminals on the caps together. I've seen them around, not sure what they're called. I'm sure you can do the same thing with wire, just wouldn't look as clean. I'll look around for these bars I speak of.
yea i looked into that already and looking into purchasing the link buss bars.. but again.. what wires goes to what??? it doesn't give the diagrams or tells you how to hook it up.....
indiglosolara
Solara 2 xB
Solara 2 xB
Postby HKSV6SLE » Fri Jan 09, 2004 3:32 am
buss bars are a good way to go. you could wire them up in a row, um better yet ill take a pix of how mine is done and post it up....
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby indiglosolara » Fri Jan 09, 2004 11:33 am
HKSV6SLE wrote:buss bars are a good way to go. you could wire them up in a row, um better yet ill take a pix of how mine is done and post it up....
Thanks Jeff..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby prophesized » Fri Jan 09, 2004 12:29 pm
you know its .5 farad for every 500 watts right? so you dont need two farads unless your amps are putting out 2000 watts rms and even then a cap isnt gonna help with that much of a load on your system.
prophesized
Postby indiglosolara » Fri Jan 09, 2004 1:19 pm
prophesized wrote:you know its .5 farad for every 500 watts right? so you dont need two farads unless your amps are putting out 2000 watts rms and even then a cap isnt gonna help with that much of a load on your system.
well i have a total of about 900 to 1000watts RMS.. dont know max didn't calculate it..
But i wanted to use 2 1 farad just in case.. better to be safe then sorry..
plus right now if i bump my system im getting flickering... not from my headlights but from my dome and interior lights..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby prophesized » Fri Jan 09, 2004 4:41 pm
get a better battery instead of another cap
prophesized
Postby indiglosolara » Fri Jan 09, 2004 4:58 pm
prophesized wrote:get a better battery instead of another cap
i just got a new batt not too long ago.. im going to give the cap a try and it if still doesn't work then ill get a new batt.
i already ordered the cap and buss link bars.. just need to get the wiring diagram...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby indiglosolara » Sun Jan 11, 2004 10:58 pm
:bump:
anyone got anything!!!!???????
im gonna make my amp rack and set-up everything next weekend....
so i would like to make sure i have it setup right...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby B_Master_Flash » Wed Feb 04, 2004 4:10 pm
Sorry but I have to say this, extra caps do ABSOLUTELY NOTHING to benifit your electrical system. Now that I've gotten that out of the way, Caps are just wired in parallel to your amps and can go anywhere. You can plug the + of one cap to the + of another cap, and the - to the -. Or get a distributor block, and plug both your +s into that and ground your -. There is no special way, just plug the + into your main power wire, in any way shape or form, then ground the -.
B_Master_Flash
Postby indiglosolara » Wed Feb 04, 2004 7:46 pm
Thanks for the advice... I installed them temp. and tested it....
Actually it helped my system a bit better then when i was running 1 cap... i dont get flickers or any seems of power lost...
I'm still thinking about getting a extra battery but for now.. im pulled my system out last weekend to finsh up my trunk..
Ill take pics when im done....
indiglosolara
Solara 2 xB
Solara 2 xB
Postby HKSV6SLE » Thu Feb 05, 2004 3:22 am
i have a good test cd. it will show where your losing power.
www.lexusnet.com
HKSV6SLE
