SolaraGuy.com • View topic - plans for system
plans for system
plans for system
Postby AzN_DrAgoN48 » Tue Feb 03, 2004 5:49 pm
here is my plan for my system. need opinion fast.
2 - Alpine Type R 12" Subwoofers
1 - JBL Power Series BP600.1 600w x 1 AMP
1 - 4 guage wiring kit
1- MTA high performance Capacitor 1 FARAD, 20 VDC, 95 Degrees C ± 10 %
and a box.
this system costs about 450.
what else do i need to run it from my solara? how will the set up go?
or should i go with 2 12" kappa perfects
1 jbl bp1200.2 amp those two alone are about 450. and i would also need a cap, wires and box. so this would cost about 600.
another choice: tba (two 12" polk momos 1 Phoenix Gold 1500 watt class D momo amp, don't know the price) so opinions?
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Postby kubi » Tue Feb 03, 2004 7:56 pm
Well if you don't have a head unit you'll need a line converter or a new head unit. You'll need additional wiring and ring connectors to hook the cap up. Other than that, nothing, really.
Please stop humping my car, owner privilege!
kubi
Postby AzN_DrAgoN48 » Tue Feb 03, 2004 8:32 pm
i have an aftermarket headunit
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby prophesized » Wed Feb 04, 2004 9:37 am
you need a cap. if you can you should give the type R's a little more power. a thousand watts for the pair would be nice.
prophesized
Postby B_Master_Flash » Wed Feb 04, 2004 3:57 pm
He already listed a cap, and doubt he actually needs it. Your primary list sounds nice, Alpine type Rs are good subs, and you can go w/ more power. I forget what they're rated (300wrms?) but they can handle around 600wrms ea. Your secondary list however... Polk subs are OK (I would go w/ Alpine myself) and the Phoenix Gold Amp you listed, I'm guessing the Octane R? Thats the only Phoenix Gold line that offers a 1500w Class D I think, anyway, it would most likely run you well over your entire budget, knowing Phoenix Gold.
B_Master_Flash
Postby HKSV6SLE » Thu Feb 05, 2004 3:24 am
id say go with the type r's.
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby AzN_DrAgoN48 » Thu Feb 05, 2004 8:40 am
should i buy another jbl 600.1 amp, and run one sub to one amp and the other to the other?
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby B_Master_Flash » Thu Feb 05, 2004 9:13 am
AzN_DrAgoN48 wrote:should i buy another jbl 600.1 amp, and run one sub to one amp and the other to the other?
You absolutely can, but if you want more power it's usualy cheaper to just get one bigger amp, I dont know what your budget is, but you can find a HiFonics BX1000D on e-bay for just over $200 and its a great amp, 1000wrms.
B_Master_Flash
Postby kubi » Thu Feb 05, 2004 11:35 am
I can probably get you a good deal on a Concept 1200 watt Class D, or 2400 watts if you want. New in box, if you're interested I can find out.
kubi
Postby AzN_DrAgoN48 » Sat Feb 07, 2004 10:30 pm
so i got the alpine type r 4ohm package. (2 - Alpine Type R 12" Subwoofers
and a box. )
now i need help wiring. krooked? anyone good with wires please help.
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby kubi » Sun Feb 08, 2004 3:15 am
Well.. make sure you run the RCAs and power down opposite sides of the car. If you search there is a post somewhere with pictures of where some people ran their wires. When you're connecting the ground make sure to scrape away the paint on the frame to get a good connection. Other than that the hardest part is tearing everything apart and running it through. If you want some pictures/instructions I might be able to put something together.
kubi
Postby AzN_DrAgoN48 » Sun Feb 08, 2004 9:23 am
thanks kubi that would be great. why should i run the rca and power down different sides? and how do i bridge the subs to the amp? sorry i'm very audio-challenged
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby prophesized » Sun Feb 08, 2004 9:59 am
you dont need to bridge anything because its a mono amp. just wire the + to the -
prophesized
Postby AzN_DrAgoN48 » Sun Feb 08, 2004 10:10 am
do i need to bridge each of the voice coils? each sub has 4 connections and the box as 2.
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby OKANG. » Sun Feb 08, 2004 10:39 am
I'm not sure what you mean by "bridging" the voice coils. You have two choices: parallel the coils, or run them in series. Running them parallel will halve the resistance (two 4ohm coils would result in 2ohms if run in parallel). Running them in series will double the resistance (two 4 ohm coils would result in 8 ohms if run in series). The amp is probably 2ohm stable, so run them parallel (just run both sets of speaker wires into the same output terminals).
OKANG.
